Wiring up back up camera help
Buckeye2019
2018 Cummins
What wire to tap into to have rear view camera on 8.4 from rea view mirror. I have a 2015 crew I also have new rear view mirror for uconnect so I have to wire so the back up camera will display on RA4
Buckeye2019
Buckeye2019
2018 Cummins
Well I took the wires from the passenger side where you connect the rear view mitts into 8 9 10 I believe with harness connection rear view mirror harness. Plugged them into 31 32 33 on back of the radio harness there were wires in those slots took them out plugged all back together and nothing all was dead. No HVAC no radio. So I put the 3 wires back in and all work. NO BACK UP CAMERA. What wire do I use behind the radio?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Are you positive you had the correct wires for 31,32,33?
If you look closely, there are numbers embossed on the connector...
See http://www.ramforum.com/showthread.php?p=978566
Sent from my LG G4 on Tapatalk.
