wont start
wstmotorsports
i have a 2004 with A 5.7 i was going down the road an it made a little popping sound and cut off an now wont start back helpppppp.
HemiBabe
DFW
Is it turning over at all? Or just tryin to start and won't fire? Need a little more info
[ tapatalkin ]
HKkid
Missouri
Going to need a little more info than that...like HB said is it trying to turn over or not giving you anything at all?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
A little popping sound could easily be a fuse. Have you checked them all?
W
wstmotorsports
it is turning over. i checked the fuses and they are good. can u take a test light and check the fuel pump plug or do you need to use a multi meter?
HKkid
Missouri
Have you done anything lately that you don't normally do with it?
txbass06
NE Texas
5.9 Magnum
I don't think they've got an inline filter. Just the strainer on the bottom of the pump in the tank.
You should be able to hear the pump kick on when you turn the key on
Sent from my iPhone 4 using Tapatalk
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Mark is correct the filter is in the tank. Did the pop sound like a back fire or what?
