Yet another Bilstein 5160 question...
BDWheeler13
Hey all! I'm hoping someone here has a bit of experience with an issue I'm having... The vehicle is a 2016 1500 Sport 4wd crew cab with about 115K miles on it. I've had Bilstein 6112's (set on clip 8) and 5160's with the +1 Bilstein rear coil spring for almost 6 months now. For the first 100k or so I had 5100's with stock springs. Ride quality with 5100's was pretty unremarkable from what I recall. Nothing bad to speak of but also nothing to write home about. Ever since I switched to the 6112/5160 I have noticed 2 things that have been driving me nuts.
#1 is a significantly harsher ride on my crappy country roads. Handling is tight with minimal body roll and when I do take it offroad they soak up tougher hits really well. But on road they are teeth chattering stiff. I've tried airing down to 35lbs with not much relief.
#2 There is a slight bounce in the rear end over even the smallest bump. Its not axle hop; its more like a dump truck trying to accelerate. I've brough it in to the local shop and they said they didn;'t notice what I was talking about so that wasn't helpful. I tried swapping springs to a progressive spring with the same lift and didn't notice any change so I'm still not sure what could cause it?
As far as the harsh ride quality, I'm just assuming its the way the shocks are meant to be so I'm not sure there is a fix to that. If anyone has any suggestions though, I'm open. But for the weird hop in the rear end, I'm wondering if a rear-end kit from Core 4X4 would help with that at all? I'm not really sure how all the components work so I thought I'd ask before I just go buying stuff.
I'm also not against scrapping the 6112/5160 and going back to 5100 or even trying something the Fox 2.0? I would just like to get some advice before I go blindly making changes like that.
Thanks in advance!
Daw14
South Florida
No issue before the change , sounds like the new stuff was in the wrong direction. It sucks having to replace again but that’s how it goes sometimes.
B
BDWheeler13
Very true. Unfortunately since I don't have the stock springs anymore it's even more expensive to go back to 5100s. Actually pretty close to a set of Fox 2.0s so I wonder if they'd be worth a try?
Appreciate the input!
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Thanks in advance!
Either one of the shocks is bound up or the suspension components were tightened in the air and your bushings are screaming
mrack
What quick shifter said, have to loosen and retorque all suspension bushings under the weight of the truck whenever you change the height. I had to learn that the hard way lol
B
BDWheeler13
Appreciate all the input!
So, I loosened and retorqued all the trailing arms, control arms, shock mounts, and basically anything related to the suspension. Unfortunately, it seems that was only half the issue. The hop was definitely less but not totally gone. I brought it to another shop and they thought it might be my tires. Something about the belt separating and maybe causing the tires to be out of round. Honestly I was skeptical about that but since I was pretty close to 45k on my Toyo AT IIs I figured it was plausible.
Since I am also not happy with the 6112s I figured this would be a good time make a big change. Ordered new wheels, tires, and a 4inch superlift with bilstein 5100s. Supposed to be installed on Monday so hopefully my whiny nitpicking saga ends next week.
Thanks again for the input!
olyelr
Kewadin MI
Going from 6112’s to 5100’s?
B
BDWheeler13
Yeah, its what came with the lift and what I had before.
DILLIGAF
Canadian Forces
Canada
6112 arent for pavement princesses with sway bars ;) Thats probbaly why you hate them.
Justin33
Sorry for the bump, but how do you like the super lift?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Zone and BDS have the best geometry of them all. Procomp and Fabtech are just under that bar. Every other brand is below the top 4. Meaning they don’t make the list. Super lift was able to make the deal with Mopar but as we all know corporate deals are made at tables and not on shop floors. Readylift makes a lot of great products but Rams are picky little Diva trucks as many that have spent time reading understand. If your kid eats every vegetable but Brussel sprouts do you try and ask all of the kids friends how they like eating them?
Your rims 17's? It can make a huge difference, why I went from 20 to 17s.
For me bills 5100 set on 2.75 was a smooth ride then the same shocks set to 2.1.
Bummer I feel your pain, gl with it.
cdub5
