FF1899
So obviously sick of the terrible sound quality from the update I decided to experiment a little. I have a 4 channel going to the doors and dash speakers and a 1000x1 driving each sub in the fox box. Since the update and having do turn the bass so far down it cut about 75 percent of the bass from the subs also. I decided to go to the local audio store here and picked up 4 bass blockers (300hz) and wired one up to each of the 4 channels running to the doors this limiting the amount of bass the door speakers will receive and giving me the ability to turn the bass back up on the 8.4 to reap some of the benefits of driving 2 12s under the back seat. It is obvious temporary until uconnect (if they ever do) fixes the **** update. I will say the quality is a little better because it is cutting some of the over powering back. It's not nearly as good as it was pre updated but definitely much better then it was before installing. I am able to fill some of the sound in with the subs and not having to rip the door and dash speakers apart. This can be done without an amp running the speakers also you will just have to find a good location to tap the speaker wires or go from behind the screen like I did to wire the amp. For the $20 I spent and 30 minutes it took to wire I would highly suggest it to others especially if you have subs to compensate.
