Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Towing & Hauling
Towing & Hauling
Ram 2500 Hemi vs 3500 SRW Cummins
This is a discussion on Ram 2500 Hemi vs 3500 SRW Cummins within the Towing & Hauling forums, part of the 4th Gen : 2009 - Present category!
What follows is a series of tests a buddy and I did using his Silverback by Cedar Creek 5th Wheel ...
Like Tree10Likes
Reply
Old 09-11-2014, 11:39 AM   #1 (permalink)
Ram Year: 2014 RAM 2500
Engine: 6.4L Hemi
Thumbs up Ram 2500 Hemi vs 3500 SRW Cummins - TEST FEST!
What follows is a series of tests a buddy and I did using his Silverback by Cedar Creek 5th Wheel RV. It's 40 feet long, and loaded as it was, it weighed in around 14,000#.
We did mpg tests, suspension squat tests, and 0-60 runs with each truck.
My truck is a 2014 Ram 2500 Crew cab, 4x4, 6.4L Hemi, 66RFE auto, 4.10 axles, Laramie pkg, equipped with the Ram rear coil springs without the air suspension. The 6.4L Hemi is 410hp/429tq.
His truck is a 2014 Ram 3500 SRW Crew cab, 4x4, 6.7L Cummins, 68RFE auto, 3.42 axles, Laramie pkg, equipped with the Ram 3500 rear leaf springs an no air suspension option. His engine is the 370hp/800tq version.
Both trucks have the same wheels and tires, and are completely stock with under 5000 miles on each truck. I drove my Hemi truck for all tests, and my friend (SKG) drove his Cummins truck for all tests.
As far as the squat testing goes, we spent a little more time and took good measurements. The RV is a 40' Silverback by Cedar Creek 5er with 4 slides. It has a 15,500# GVWR and likely ~2700 to 3000# hitch weight.
We measured each in the same spot on the street in front of SKG's house hitched and unhitched, and the space before the bump stop would make contact on each truck.
RAM 2500 6.4L Hemi (with rear coils)
Unloaded, 42.5":
Loaded, 39.8":
Total sag, 2.7"
Space between jounce bumper and axle perch (before suspension bottoms out) when RV is hitched up, 1.8"
Overall view** Keep in mind, my 5er hitch is set too high for his RV and the airbag pin gizmo he has on there, so the RV was a bit nose high when hitched to the Silver 2500 Hemi (my truck, SKG's RV).
2014 RAM 3500 SRW (rear leaf springs)
Unloaded, 42.25"
Loaded, 40.25"
Total sag, ~2"
Space between jounce bumper and axle tube (before suspension bottoms out) when RV is hitched up, 2.75" (angle is bad for camera, but it was just under 3" by eye)
Overall view at same spot on highway:
That's all the static testing covered. Now onto the driving tests.
0-60 test towing 14,000#
Impressions (my opinion):
The Hemi built power smoothly and had the more power at higher RPM (duh). It was a very predictable flow of power, and didn't seem "lacking" at all. It does have the characteristic flat spot in the power as soon as it changes from 1st to 2nd gear as the step between those gears is pretty large. It takes the engine a few seconds to recover from that gear change. I would best describe it as "adequate" power (IMO) for the load. The "clunk" you hear right at the end is from the fancy airbag hitch on the 5er.
Hemi 0-60 towing 14,000#
The Cummins powered truck was a completely different experience. It tugged like crazy in first gear from about 1500 - 2500 RPM, then the power kind of drops off at higher RPM and as the trans shifts between gears. Fully uncorked and not held back by the computer, the power is much more evident than with the Hemi. I don't care what anyone says, the power output is definitely being "managed" by the computers. There are stark differences between full ON (I'd call "impressive") and tq managed when the accelerator is held to the floor. When the RPM and speed are right and the computer isn't choking the power it pulls amazingly hard - even with the heavy load we had behind it.
Cummins 0-60 towing 14,000#
MPG test towing 14,000#
OK, firstly, I know this is not as scientific as could be done. But remember, we're just a couple of guys, not scientists. We ran each truck at the same speed on the same road, towing the same RV one after another. We let each "settle", after accelerating from a stop, then started the video recording. The passenger did the recording, so the angle isn't ideal, but you can see the mpg display on each hopefully.
I also didn't want to post a 10 min video of each test. It takes FOREVER to upload and it would be boring to watch. Each video is around a minute long.
We each had a side/corner wind to deal with, but it had a much more detrimental effect on the Hemi mpg as it had to work harder to maintain speed. The Hemi would run in 4th gear at about 2500 RPM (6 speed auto trans) when hitched up. With my lighter 5er (it's about 12k#), it will usually run in 5th. The Cummins quickly settled into top gear (6th) at just under 1400 RPM, even with the load.
6.4L Hemi & 4.10 gears - mpg towing 14,000#
6.7L Cummins & 3.42 gears - mpg towing 14,000#
The side wind we dealt with gave us a chance to compare the chassis and road feel of each truck. The 5er we were towing has a very large, high, flat front cap, and a tall side profile. Personally, I didn't feel either truck was "unstable" at all. Each felt confident and stable; it was quiet and relaxed in the cab. I will say that the 3500 SRW felt a little "stiffer" in the rear than the 2500 - makes sense I guess based on the squat measurements. If the 2500 was a 9/10 for stability (just an example), the 3500 SRW was a 9.5/10.
I welcome your comments.
loveracing1988 and JRG18 like this.
Sponsored Ad
Register to remove this ad.
crashguy is offline   Reply With Quote
Old 09-11-2014, 12:41 PM   #2 (permalink)
Ram Year: 2015
Engine: 6.7L Cummins
Default
Very interesting and at a good time for me as I am currently researching for my next tow vehicle.
Question, isn't the pin weight a bit too much for the 2500 since it (CC short box) has a maximum payload of 2,370? Even the 3500 has a maximum payload of 3950, after subtracting the pin weight and the driver and passenger, that doesn't leave much capacity.
I may not understand payload correctly because I see a lot of 2500s pulling massive fivers in Michigan's UP.
crashguy likes this.
BossHogg is offline   Reply With Quote
Old 09-11-2014, 01:03 PM   #3 (permalink)
Engine: 6.4L Hemi
Default
The payload of the 2500 (mine) is just over 3000# -- maybe your figures are for a Cummins powered truck? Mine is a Hemi (lighter). The 3500 SRW Cummins is just under 4000#. The guy that owns the RV drives the 3500 diesel in the pictures. Both haul it just fine as our testing showed. That said, I wouldn't consider my truck (silver 2500 Hemi) and HIS RV to be a perfect match. My RV - the one I regularly pull with this truck, is about 2500# lighter and 2.5 feet shorter with one less slide than this monster.
Old 09-11-2014, 07:24 PM   #4 (permalink)
Power247's Avatar
Ram Year: 2012
Engine: CTD 6.7
Default
Thanks for taking the time guys
crashguy and Ratket like this.
__________________
Build Thread Upgrading the factory Alpine system
2012 2500 4x4 CTD Big Horn CCSB 3.73|Flo~Pro|SIMS|XRT Pro w/MCC|Edge Insight CTS|Infinity|JBL
2009 1500 4x4 HEMI Big Horn CCSB 3.55|Volant CAI|18" Magnaflow|Airlift1000|Superchips Flashpaq 3865 - SOLD
Power247 is online now   Reply With Quote
Old 09-12-2014, 07:04 AM   #5 (permalink)
loveracing1988's Avatar
Ram Year: 2014
Engine: 6.4
Default
Did you actually time the 0 to 60 runs or just record them? The video length of the 6.4 is 4 seconds longer but you also talked in the beginning. It looks like the Cummins is faster but not by much.
__________________
loveracing1988 is offline   Reply With Quote
Old 09-12-2014, 08:07 AM   #6 (permalink)
Birddog's Avatar
Ram Year: 2016 Bright White 3500 Laramie 4X4 Long Bed
Engine: 6.7 Cummins TD, 3.73
Default
Nice test. I wonder what the MPGs are between the two. My real question is, if I weren't planning on keeping my truck more than 2 years (the long term diesel advantage) would I be better paying more for the Cummins or maybe the fuel savings isn't that far apart between both vehicles that I'd want the 6.4 Hemi.
__________________
Bak RevolutionX2 Tonneau, Amp Resch Bed Step
Clubs: WhiteTruck#62, 4X4#12, CTD#32, LowMiles#23, AftrDrk#54, Tattoo#38, ChopShop#11, Supporting Mebr#53, RF Hunt, Gun, Military, Motorcycle
Birddog is offline   Reply With Quote
Old 09-12-2014, 01:02 PM   #7 (permalink)
Engine: 6.4L Hemi
Default
We didn't have a stop watch, but if you watch the videos closely, I think they are both about 22 seconds to 60 mph.
Old 09-12-2014, 01:03 PM   #8 (permalink)
Engine: 6.4L Hemi
Default
The towing mpg is in the videos. The Hemi sat at about 7 mpg once it stabilized, the Cummins at 11 mpg.
Empty, I get 16 - 18 mpg (Hemi) and SKG gets about 20 - 21 mpg with his Cummins.
Old 09-13-2014, 01:08 AM   #9 (permalink)
Ram Year: 2014 Ram 2500, 4x4, CC, SLT Big Horn
Engine: Hemi 6.4
Default
OP, thanks for the test and data.
On this question, how many miles or fillups per year for a 2 year payback?
My Fuelly says +3MPG would be $20 saved for my tank. However, going by Ram 2500 prices here locally would be about 10K price increase to CTD.
10000 / 20.00 per fill /52 fillups per year = 9.6 years,
with $28 saved per fill for a CTD, its 6.8 years.
I've calculated this other ways with similar results for my yearly mileage.
I think that initial purchase price invested would pay back much better.
I'm still happy with my 6.4, and now with 7K miles, it pulls stronger than it did new IMO.
__________________
granite14 is offline   Reply With Quote
Old 09-16-2014, 07:27 AM   #10 (permalink)
Ram Year: 2014
Engine: 6.4L Hemi
Default
Originally Posted by granite14 View Post
How many miles or fillups per year for a 2 year payback?
Fuel price can swing that by a lot, as can assumptions on fuel mileage. In my simple calculations based on fuel prices and assumed trade-in value, the tradeoff for me would have been somewhere between 90K and 120K miles based on regular vs diesel prices and based on 13mpg for the Hemi and 17 mpg for the CTD. 13 mpg is pretty accurate for mine. The CTD mpg is a swag. It seems that some people get closer to 20 (and the payback period drops to 50k miles) and others get less (at 16 mpg for the CTD, the payback period rises to 240K miles). Changing my assumptions on trade-in value makes a big difference too.
Badunit is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2500 vs 3500 ( 6.4 hemi) Drewster2012 Heavy Duty 25 07-25-2014 10:49 AM
2004 ram 3500 cummins 4wd dash light on but... demonized340 Tech Info 3 07-12-2014 05:05 AM
JBA Shorty Headers 09-14 Ram Hemi 1500/2500/3500 2wd or 4wd PaulHuntzy For Sale 1 02-26-2014 06:18 PM
05 2500 Hemi to Cummins swap Sik Kustoms General Discussions 6 07-16-2013 09:39 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
