Mishimoto's Dodge Ram 5.7L Hemi Oil Catch Can R&D
adrianp89
Tampa Bay, FL
Still blows my mind people will spend $200 on this. $50 - sure whatever. But lets be real - if this oil was truly an issue - Dodge would have addressed it years ago. This motor has been pretty much the same for almost 15 years - that oil doesn't hurt anything - and taking it out does not benefit a thing expect a false sense of piece of mind.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
How much do you think a top end overhaul, or new throttle body would run?
That will blow your mind...:biggun:
adrianp89
Tampa Bay, FL
If someone can prove to me this excess oil caused a throttle body to go bad or anything I will be happy to change my opinion. There are plenty of testimonials of these Hemi's going 250/300k with only oil changes being done. As far as I am concerned, it is a money grab. Which by all means, these companies should go for it because tons of people eat it up.
I am sure the engine functions as normal and that oil is designed to go that way. The people designing these engines are some of the brightest minds in regards to motors. If it was an issue, it would have been addressed.... on multiple motors not just Hemis.
SyN
6.7L CTD Owner
Tornado Alley
2017 4WD - Tow Prep Pkg - Off-Road Pkg - 3:42s w/Anti-Slip
6.7L CTD
Still blows my mind Millions not just a few hundred will spend way more then $200 on Cigarettes/*****/Drugs/Alcohol a week.
Compared to a 1 time buy of $195 that will last the life of the auto.
And never have too to worry about slowly killing themselves.
That is as real as it gets!
I wouldn't worry to much about owners who only spend $75-195 one time for a life time.
It's the others I would concern yourself with.
I myself consider a CAI by itself a total waste of $$$. But many owners add these kits to their 5.7L to achieve a warm fuzzy go fast feeling inside which they spent more money than me.
I have no issues or problems with that.
None of my concern!
My only concern is I will now have a dry clean air intake as well as a spotless throttlebody. I consider it very easy preventive maintenance.
One thing over my 52 old years of growing up around auto mobiles and tractors farm equipment high performance motorcycles exotic sports cars is:
Just because thousands upon thousands of owners have been doing it for years and years and are still doing it today and YOUR not ----->does not mean that it's wrong.
Mishimoto
Mishimoto
5.9L Cummins
Think of it more as a preventative measure with respect to future engine maintenance. While there are trucks out there hitting several hundred thousands of miles on the clock, our goal is to keep your truck running that long without worrying about damaged fuel emissions and engine performance due to excessive carbon buildup - which there would be plenty of if you were to inspect the cylinder heads on one of those Rams with that many miles on it.
This is still an issue from the factory for many vehicles, but manufacturers have to design these automobiles with the consumer in mind. If they were to add something like a catch can someone would have to empty from time to time, it's another maintenance activity that the majority of people won't keep up with, and you end up with an entirely different set of problems.
While turbocharged and supercharged applications almost have to have a catch can setup, certain (not all) N/A applications benefit as well. We have this well documented and is the reason we are continuing to expand our line. Our engineers know when to call it quits on a catch can project that will provide little to no benefit for the car it's being designed for. This actually happened with our 2015+ VW Golf GTI catch can project. Once we found it wasn't catching anything after several hundred miles of testing, we cancelled the project instead of moving forward. My point is that we have found good reason to put products like this out on the market. If it wouldn't provide any benefit, we wouldn't make it! This truck puts out over 40ml of blow by in just 1500 miles, which is a lot. So we know our kit will do some good.
Also, we have not set a final price point, but pricing and shipping details will actually be revealed soon. Your feedback will certainly be useful for our team in that regard. I hope this helps, let me know if you have any more questions!
-Diamaan
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
So is there a need for other engines to have a catch can ?
like Fords motors or Chevys motors ? or is this somethimg more common on the Hemis.
Hemi395
Cape Cod MA
Hemi engines in general have a good amount of blow by making the catch can a good idea.
The Ford ecoboost engines or just about any other direct injection engine, tend to suffer from carbon on the intake valves due to the injectors not washing them off. So this is another good application for a catch can.
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
Yup, when I had my 2013 F150 with the ecoboost, I was very active on those fourms too. A very hot topic was catch cans.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Your opinion, your truck, Your consequences :cheers:
Mishimoto
Mishimoto
5.9L Cummins
We've got some sweet updates coming your way soon guys. This catch can is closer to being available than you think...stay tuned ;)
-Diamaan
huntergreen
any idea how much longer it will take for this to ready for sales?
Mishimoto
Mishimoto
5.9L Cummins
An update on what the final kit looks like should be going live either later today or early tomorrow morning. The presale should start sometime this week!
-Diamaan
Mishimoto
Mishimoto
5.9L Cummins
Oil Catch Can R&D, Part 2: The New Kit!
Function and utility often outweigh aesthetics, and our engineering department has paid particular attention to the two while creating the baffled oil catch can kit for the 2009 Dodge Ram 5.7L V8 Hemi. Your Ram works hard for you, so it’s only natural to want to take as much care of your pride and joy as you can to keep it running at its best.
We already know that this truck can use some TLC when it comes to the amount of blow-by the Hemi produces. If you need a refresher, in only 1,000 miles, we caught nearly 50ml of content, which is on the high side of tests performed on other applications. It was clear that our can was working, but there was one problem – our original two-ounce can just wouldn’t cut it. You’d have to empty the can several times before you’re even due for an oil change. That’s an inconvenience we don’t want you to experience, so we came up with a solution.
Pictured above is our can, doubled in size and capacity. The can’s internals are the exact same, just in a bigger, 4-ounce can. Despite the size increase, its slim figure still allows for options when working within the confines of an engine bay. With this decision, we also had to pay attention to the bracket. Our engineer upgraded the thickness of the bracket to three millimeters, which is denser than what you saw in the previous prototype and is very beefy for what is being supported. It was also modified for a cleaner look and easier fit in the mounting location.
Here’s a look at how the finalized bracket and sizing settle into the engine bay:
This catch can kit has ample space for installation, easy access for can servicing and clears all nearby engine components. The bracket will mount on the radiator support, which has proven to be a very sturdy location on our shop Ram. Thousands of miles have been put on this truck and there are no signs of foreseeable issues.
Now that we know the final product works and will protect your engine, it’s time for us to give you a chance to get your hands on it. Within the next few days, we will make the presale live for you to purchase this kit at a discounted rate you won’t be able to find anywhere else on the market. Stay tuned for that update. Thanks for reading!
-Diamaan
Mishimoto
Mishimoto
5.9L Cummins
Great news guys,
Looks like we're going to make this available for presale purchase a little earlier than initially intended. So it's available for purchase now on our website! See below for details.
We are making our presale for the 2009+ Dodge Ram 5.7L Hemi Baffled Oil Catch Can Kit live! During this period, you can get this product at a great discount before the final production kits hit the warehouse and the market. This presale will be going on for several weeks, so you have time, but don't wait too long!
Please check out the details below and please let us know if you have any questions!
PreSale Link
Expected Release: September 2017
Pricing Details:
2009+ Dodge Ram 5.7L V8 Baffled Oil Catch Can
MSRP: $245.00
Pre-sale: $169.95
Will come in only Wrinkle Black with Black silicone tubing
Includes:
(1) Black, Anodized 6061 Aluminum Catch Can
(2) Catch Can Hoses
(2) Plastic Barbed Fittings
(4) Worm Gear Clamps
(1) Bronze Filter
(1) Air Diverter
(1) Internal Baffle & Rod
(1) 3/8" NPT Plug
(1) Large O-Ring
Mounting Hardware
Mishimoto Lifetime Warranty
PreSale Link
Again, please let us know if you have any other questions or concerns!
-Diamaan
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Pre-sale price is a good deal.
MSRP? Meh!
breal201999
I haven't installed a CC yet on my 2016 Ram with 18,000 miles, so I'm going to give it a try. Just placed my order!
breal201999
Did I make this up in my head, or did I not read somewhere in this thread or online if paying by PayPal it would be charged immediately, but if paying by credit card the charge would be held until shipped? Because it seems it charged my credit card immediately after placing my online order.
Phylodog
Arcadia, IN
2012 & 2018
5.7 Hemi & 6.7L CTD
Ordered for my new (to me) 2103. Looking forward to getting it installed.
professionalish
