2013-2018 RA2/VP2-NA Radio Notes
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
If anyone want's to share/pm me a VIN for 2014, 2015, and 2016 trucks with factory RA2's I will see about keeping track of the fw versions. (I have a 2013 Vin from my truck).
Just thought I would start a thread for related info about the 2013 - 2017 RA2 radios for those that upgrade from the RA1...
Here's the basics of what we know currently:
Previous experience is that all the 4th Gen 2013-2017 RAM RA2 radios should all be interchangeable, but it's best to match the year or as close as possible.
* Most RA2's do not require a 4 digit unlock code when moved to a new vehicle, but some do. It'***** or miss. You can get the code from the seller, a dealer (may need original vehicle Vin & radio SN), or online at https://www.carstereocode.com/unlock.php?mk=8 , NavRepair.com or similar sites ($15 or less).
Per confirmation by forum members with factory RA2's ...
Ram Truck 5.0 RA2 UConnect Multimedia Radio
Interchange Part Numbers: TBD VP2 NA
68088693AA (AB, AC, AD, AE) <- 2013
68226685AA (AB, AC, AD, AE) <- 2014
68228668AA (AB, AC, AD, AE) <- 2015
68271365AC (AA, AB, AD, AE) <- 2016 (Thanks Atom)
68271367AC (AA, AB, AD, AE) <- 2017 (Thanks mike199950)
68365210AB (AA, AB, AD, AE) <- 2018 (Thanks @Duane Pipes)
68365210AC ((AA, AB, AD, AE) <- 2019/2020 Classic (Thanks MSGRetired/Peter K.)
Note: Latest FW for 2013-2014 is SW version 5.2.20.1 (as of 1-17-17)
Confirmed:
* 2013-2014 (MY13-MY14) RA2's use the same software.
My guess (if it follows the RA4's) :
* 2015 (MY15) RA2's will have their own Sw.
* 2016 (MY16) RA2's will have their own Sw.
* 2017's are looking a bit screwy so far with the different uConnect 3.0 (RA?) vs uConnect 5.0 (Ra2) ?
I just need some RA2 VINs for 2015 and up. If anyone has some they want to share, PM me.
Related threads and info for those upgrading from an RA1 ...
- DIY: 2013-2018 RearView Mirror Upgrade & Harness install
- DIY: 2013-2018 OEM Steering Wheel Audio Control Install
- Installing OEM backup cam
** Pay attention to Post 10 as well as the OP **
- 2013-2016 Ram Radio Removal 6-27-16.pdf
or if you want to go full RA4 conversion:
- DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
2 posts for me
To do a soft reset of your Uconnect system:
1) Put your vehicle into the accessories mode (ACC or RUN) **For keyless start (push-button) vehicles: push the start button twice without having your foot on the gas or brake pedal**
2) Hold down the Phone and voice recognition buttons (or the volume and tuner buttons on your radio), at the same time, for thirty seconds
3) Let go of the buttons
4) Turn vehicle off
5) Open driver’s side door for thirty seconds
6) Close door
7) Restart vehicle
8) Let the media centre load up and see if concern is still present
If this doesn't work I would recommend visiting your dealership for further diagnosis. Let me know if you have any additional questions!
Andrea
Ram Social Care Specialist
EDIT: Possible way to check the RA2 SW Version courtesy of @kad ...
I need to find out what version of software my RA2 is running. Before I mess anything up, is the below sequence to get to the Engineering Menu the best way to find that info? I've searched all over and this is the only thing I found for the RA2.
- Version 1: Ignition ON, Engine Off,
Hold Down: Radio + Media + Browse Butttons for 5-8 seconds
*The above did not work on my radio, but ...
- Version 2: Hold down Radio + Media first, THEN holding Browse for 5 seconds did
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
3 posts for me
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
4 posts for me
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
5 posts for me
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Here's a picture of the new
2017 uConnect 3.0 radio
(UA1 Uconnect 3.0 ) ...
Conveniently I have the vr and call buttons. Just no audio controls. And mic is next to the visor. It would be nice if it will work. I don't need anything to fancy like the 8.4. Hoping to snag a uconnect 5.0 when someone upgrades to the 8.4
Can you post a picture of your radio? Sounds like you have the new for 2017 uConnect 3.0.
M² Mods - From my non Flammable S7!
Azmp1
Exactly what I need! Thank you for posting (consolidating) this!!
R.L.K.
Bristol , Tn.
Great idea Mike !
AFMoulton
Nuevo Mexico
Mike,
Just got a RA2 from eBay, super cheap. But have a problem. I plug it in and I get the Uconncet screen and nothing else happens.
I tried the soft reset, but nothing.
Suggestions? Thanks
Jeff
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Mike,
Suggestions? Thanks
Jeff
Curious. What is the PN of the radio?
Here's another reset method posted recently. If that doesn't work, then idk other then contacting NavRepair about fixing it...
Edit: this looks nearly the same as the one I quoted in post 2
"Step 1) Put your vehicle into the accessories mode (ACC or RUN) **For keyless start (push-button) vehicles: push the start button twice without having your foot on the gas or brake pedal**
Step 2) Hold down the Phone and voice recognition buttons (or volume and tuner knobs), at the same time, for thirty seconds.
Step 3) Let go of the buttons(after the screen goes black)
Step 4) Turn vehicle off
Step 5) Open driver’s side door for thirty seconds
Step 6) Close door
Step 7) Restart vehicle
Step 8) Let the media center load up and see if concern is still present"
Sent from my SM-G930P using Tapatalk
AFMoulton
Nuevo Mexico
So update, went to the dealer and had then attempt to reset it, they said it was dead and would order a new one under warranty. So now I'm waiting for that.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
You got a dealer to replace a 2013 RA2 Radio under warranty? Good Job!
(I assume it didn't come factory in your truck)
AFMoulton
Nuevo Mexico
No, I had the RA1, and the Tech new, but said your truck is under warranty and this is a stock radio. The service manager agreed with him. So there we go.
R.L.K.
Bristol , Tn.
Wow that's unbelievable , ha ha I thought one of my local dealers were idiots , but yours takes the cake
I've fortunately found a great dealership local with really good techs , I hope I never need to use them again , but if I do at least I know there's a good one local .
Sent from my SM-G900V using Tapatalk
AFMoulton
Nuevo Mexico
LoL idk if it was that they are idiots or if maybe being in uniform helped. But they were totally cool about it
gwjeff
Questions!!!
I have a 2017 2500 Crew Cab 4x4 6.4L Tradesman..
I removed the original RA1 (short version, no SiriusXM) and installed an RA2 5.0 out of a 2015 RAM 1500 (long unit with SiriusXM). The swap was for two reasons; 1) to get SAT radio...love my XM and 2) to get BT and hands free phone ability.
I installed an Antenna Specialists XM antenna, works perfectly. I also installed the rear view with microphones from another 2015 RAM 1500 and a new wiring harness from Tasca. I pinned the backup camera from the original rear view to the head unit, everything works ACCEPT the hands free for the phone!
Any ideas as to why the hands-free mics are not working?
Everything plugged in and bolted up beautifully, just no hands free! Could the Tradesman be missing some wiring between the modular plug at the passenger side dash receptacle to the head unit? Does it need a reset? A flash update? Any help is appreciated, this is bugging the crap out of me.
AFMoulton
Nuevo Mexico
So I just did pretty much the exact same thing on my 2016 1500 Tradesman and it all works just fine, I don't have the buttons on the steering wheel yet, but that's next as soon as a steering wheel comes available
Markks
2016 Express RCSB 4X4
Pentastar
Does anybody know if there is any differences between the Jeep RA2 and the Ram RA2??? It seems the Jeep RA2 sell for less than the Ram RA2.
Thanks!!
Mine is the RA1 with XM and the Backup Camera in the Mirror...
2016 Express...
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Thanks!!
2016 Express...
You can verify PN's from the OP. If it matches, you should be good. We have been using 8.4 radios from 13-17 Cherokee's, & Vipers in Rams without issue.
Fyi, NoClass has a Ram Ra2 radio, manual mirror w/mics, and a backup camera Reroute harness to send the backup camera into the new radio. Good price too.
See...
http://www.ramforum.com/showthread.php?p=1562248
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Anyone have a PN for the 2017 Ram Ra2's they would care to share so I can update the OP for others?
