Rough country N3 pre loaded struts
  • Do they work with oem lca
    Votes: 0 0.0%
  • I dont know what this is for
    Votes: 0 0.0%
  • Total voters
Mvansciver
I have a 2012 1500 with a 6” zone lift kit with 35x13.5x20 toyo rt’s. I just replaced the lower control arms with moog arms that have new balljoint and bushings pre installed. I also am replacing my stock strut that has the lift spacer on it with rough country n3 pre loaded struts for a 6” lift. Does anybody know if these struts work with oem lower control arms because when i went to bolt up the strut to the control arm i had to flex it inward towards the truck to get it to seat around the lower control arm bushing. Will this cause the strut to fail sooner because of the inward flex or will it straighten out when i put the truck back on the ground when the suspension is loaded?
