Inez Hotrods 4/6 Drop
Quicksilver337
South FL
2016 Ram R/T
I installed the Inez 5/7 drop over the weekend and my tie rods are bottomed out making my toe out of wack. I haven't trimmed the tire rods I'm not sure if I need to trim the outer or the inner one that's attached to the rack. I only cut 1-1/2 coils out back i am thinking of taking out another half coil.
the inner tie rod end needs to be cut 3/8"
Easier to cut the outer tie rod end,either end works,but the outer is far easier to get at. Wind the jam nut on ,and carefully use a cut-off disc in a side /angle grinder ,clean up the threads a bit before you wind the jam nut off and on a couple times and you'll be good to go.
aramos3
I took a look at my suspension and the jam nut is pretty much at the end of the thread of the inner tie rod it cant go any further looks like i will have to cut 3/8 out of the outer and inner tie rods to get the toe into spec. I will give it a shot this weekend.
Thanks guys.
Quicksilver337
South FL
2016 Ram R/T
You have a good point there, I need to do this as well...
gonzo1968
Az
aramos3
What shocks are you running and what are the tire dimension>
I am running 265/40/22 front and back. With the belltech 2/4 I was running QA1 all around, now that I went with the Inez drop arms I swapped out the front to the stock shocks and springs left the qa1’s out back.
gonzo1968
Az
How difficult was the arm install? I already did the cut brackets, just need to sort the front.
aramos3
Up front is fairly simple and straight forward, remove and reinstall. I still need to trim the tie rods but thats simple enough. The rear is a pain especially on the ground with a jack and stands.
mighty noid
Culver City
Hydro Blue 2018 4x2 Sport Crew Cab
Thinking about changing my tire size with my 4/6 drop to the following:
Front 285/40/22
Rear 305/40/22
I am sitting right now on 285/45/22 all around and I get some slight rubbing on big dips and tight turns on the front..
Anyone with this set up???
crash
Woodstock, ON
I'm running 305/45/22 tires in all 4 corners with no issues.
Front 285/40/22
Rear 305/40/22
I'm guessing a different wheel width and offset between the two of you guys would make a difference regardless of tire size. what wheels and offset are each of you using?
ramittome
Gonzales, LA
All 4 corners are 22x9.5 with a +25 offset and an extra 1" spacer to clear the a arms.
All 4 tires are 305/45/22.
mighty noid
Culver City
The OEM 22" in black
crash
Woodstock, ON
I think the offset on the r/t wheels is +19. and your width is a half inch narrower.
that may explain it. they would be sitting farther out in the wheel well, closer to the fender lip than the +25 offset, which would sit further into the wheel well... I think? or, do I have that backwards (it's early lol)
ramittome
Gonzales, LA
His would be sitting closer to the truck by 0.7" on each corner after you factor in my spacers. Basically puts me at a 0 offset.
ramittome
Gonzales, LA
Ok everyone, check your rear control arm brackets. My drop is less than 2 years old with less than 30k miles on it got under it today because I've been hearing a lot of noise lately, and well.... all 4 of my rear control arm brackets that come with the kit are cracking, with 1 of them being almost all the way cracked in half. Co tacted Inez, waiting to hear back on what he says about this. Not sure what type of warranty there is on it, or if I'm just sol.
20190130_110253.jpg 20190130_110259.jpg 20190130_110312.jpg 20190130_110339.jpg
Txhemirt
Lubbock, Tx
View attachment 153754 View attachment 153755 View attachment 153756 View attachment 153757
I read the Inez felt weak when compared to the illicit. Please let us know how ihc handles this! Sucks man
predat-r
4.7 v8
Thats messed up for sure, hope they replace parts. Hope they don't pull that we didn't do the install bs.
Sent from my SM-N920P using Tapatalk
ramittome
Gonzales, LA
I'm sure iys gonna be something along those lines, that's if I even hear back from them.
