Mopar Bright Pedal Kit 82212138 for Adjustable Pedals
Deepc6
Long Island
Hemi 5.7 Etorque
I have seen many members add the Mopar Bright Pedals to their trucks which looked great, so I decided I wanted a set. I have a 2016 Limited do my truck came with adjustable pedals. Mopar states the Bright Pedal kit does not work with adjustable pedals. I looked up the dimensions for the bright pedals and the factory black rubber pedals they seem to be an exact match. So I decided to take a gamble and ordered them from amazon “since I had a credit with them” in case they don’t work so I can return them.
Well after the about 20 minutes. Wrestling with the brake pedal this is my result.
They in fact do fit not sure why all the specs say not for adjustable pedals.
wink
Beast Pilot
Golden, Co
2017 1500 Sport RCSB
Good to know! I'd like to put them in my Ram too. My Jeep SRT8 came with them from the factory, but not installed. They were a bit of a PITA to get on, but just required a little elbow grease. The Jeep has adjustable pedals as well, and they've not budged in 8 years.
wink
norton333
Don't worry they fit perfectly, I put them on my 16' sport with adjustable pedals, no problems.Your bottom pic is the correct set top is not(at least for my 2016).
Jwithing
STL
I'm gonna wait for the ram dead pedal to come out to see if it matches this kit.
BWL
Embrace the skeptisism
BC Canada
Thanks for the info. I just ordered a set
Deepc6
Deepc6
Long Island
Hemi 5.7 Etorque
I recall a member here who installed Mopar parking brake cover off a challenger or charger does anyone recall which one? I would like to make it match if possible.
2016Bighorny
Wisconsin
I had a set of these on my 2012...I might just have to order another set for my '16...
Jwithing
STL
I have seen many members add the Mopar Bright Pedals to their trucks which looked great, so I decided I wanted a set. I have a Limited do my truck came with adjustable pedals. Mopar states the Bright Pedal kit does not work with adjustable pedals. I looked up the dimensions for the bright pedals and the factory black rubber pedals they seem to be an exact match. So I decided to take a gamble and ordered them from amazon “since I had a credit with them” in case they don’t work so I can return them.
According to JEGS, the if pre 2009 and adjustable pedals, then you should use 293-82211711AB
Deepc6
Deepc6
Long Island
Hemi 5.7 Etorque
According to Jegs 293-82211711AB this is for a charger, Mangum and Chrysler 300
kad
Hudson Valley, NY
5.7L HEMI
Where did you see that a dead pedal was coming out? Is Mopar producing it or an aftermarket company?
-K
Jwithing
STL
Uh... Wtf... Am I missing something... Accelerator pedal doesn't just slip over and it seems to be just one piece... 2015 cc sportIMG_20180412_173430.jpg
stimpy433
IOWA
Uh... Wtf... Am I missing something... Accelerator pedal doesn't just slip over and it seems to be just one piece... 2015 cc sportView attachment 125419
If you look at the first post there must be 2 different versions as his pic shows a wide pedal at the top like yours. If you look at the other picture, it looks like what you were sent.....
Edit: I just looked and that is the same gas pedal as on my Challenger.... you must have got the wrong kit???
Jwithing
STL
Well... ****... Guess I'll just drink beer instead of drinking beer and playin with my truck
stimpy433
IOWA
The Challenger guys use the Mercedes e brake pedal, it fits perfect with a little modification.
stimpy433
IOWA
I put this on my son's Challenger worked great but will not work on a RAM, you need a Challenger clutch pedal.
Oh, the Ram e brake must be bigger, I guess I never compared them. Good to know!!!
