mondo
- Aug 4, 2014
- 954
- 482
- Location
- Columbia, Pa
- 2014 2wd express rcsb
- 5.7
Just get it all done for the modern hemi shootout in Fla in March
Do you go to any of them?
Hey man, thanks for the advice. I am very new to Dodges, so any words of advice are welcomed.
I have to make a correction the pistons the truck has are Mahle (not Manley) cast pistons and they have the chrysler logo on them. As I had mention on an early post I took a peek into one of the cylinders thru a spark plug hole using an inspection camera and saw that the piston are thermal coated, so that's a plus
What do ya know, exact same place I remounted my washer fluid tank too, yours is just a lot bigger than mine which only hold 1/4 gallon. Have a look at the tank and cap and make sure there's a vent to atmosphere or you can start pulling a vacuum on the tank and your washer pump will stop working, generally when you need it most. I drilled a small pinhole in the water neck and haven't had an issue since.
I would highly recommend the water **** kit, even when I was running low boost I would see ambient intake temps with my kit and now with higher boost I'm about 10*C over ambient with the w/m and intercooler.
As for the intake, I'll just say that I'm an aerospace structural engineer so I have a bit of a background in air flows. That pipe is going to be an issue for you, it's not the inlet area that's the issue, its the inlet design. You need 969.4cfm at 6400rpm or take a 90%VE and you get 862.5cfm and I'm estimating the tube size is 5"Dx16" based on relative size (it's a guestimate I admit) which has a volume of 0.18cuft. You require 5385.5 or 4791.6 air changes per minute and you're trying to squeeze that through a space that is 0.44ft^2 and is not aerodynamically friendly because of the abrupt angle change required.
With the very rough math while travelling at 60mph your intake will be eating a very small path of air because you're restricting your inlet space so at 60mph you will literally only have a path of ambient air that's 38.8ft^3 and being generous with an additional 25% for potential slipstream effect into the inlet that's 48.5cfm and remember your requirement is 862.5cfm. Now are you seeing why I'm concerned about your inlet tube?
