RusslRam
- Jan 21, 2017
- 564
- 498
- 2013
- Hemi 5.7
I really like it. Definitely not your everyday retrofit.
Sent from my Pixel using Tapatalk
Same here. Output should be awesome.I really want to see the light off these at night!
$1 less than the Morimotos and I promise you'll get them before everybody else does hahahaha. Nah, not making any more of these. You would have to throw some big coin my way to make another set lol.What you charge to make a set like this?
I was able to get the extra leds for my turns welded in on the passenger side.
Testing
Letting the JB Weld to set
Final product. Might add one to the top but not sure if I will have room on the backside.
I did have an issue with the projectors flashing when the engine was running. After some research on teh AlfaOBD thread (which I received yesterday), I diagnosed it as PWM. After seeing switching the computer to see HIDs, NOT Leds like you might think, the PWM is gone and they run smooth.
My only issue now is the white running lights are still flashing when hooked up to the truck. Work fine on the bench, but they have a inconsistent flash and the amber leds glow slightly when they are off. Contacted DiodeDynamics to see if they have encountered this before.
Testing
That’s just it, they are set to LED. Just for curiosity I switched the led park lights to “no” with the Alfa before I called it quits yesterday and will test it today to see if it changes anything. I know with the low beams, if it’s set to led it will still send the pwm, only set to HID will that go away.Make sure you have turn and parking lights set to led's
Thanks. But my issue is with the park lamps not the low beams. My low beams were flashing but I changed a setting with the AlfaOBD and solved that.I had the same and used the diode dynamics canbus adapters. Problem is solved.
https://www.amazon.com/gp/product/B07PG2VFHT/
