Strictly the 4x4 lowering thread...
VB712
Maxi_built
Va Beach
I put mcgaughys 2" drop springs on the rear of mine. The ride is great but for some reason the driverside rear sits about 1/2" lower than the passenger rear. Double checked to make sure they are installed correctly. Even rotated the driverside spring to see if made any difference.
Anyone else have this issue?
1qikdsl
This isn't uncommon. Mine did this with stock as well as lowered. My OCD got the best of me and I pulled out a cutoff wheel. I don't recall if it was a half or full coil removed since it was done to both my stock and lowering springs. It's a quick job and he spring still stays tight in the bucket if you end up going crazy over it like I did. Once I noticed mine I more often then not could see it in most 1500 4x4. 2wd doesn't seem to do it for some reason. I believe mine was .75 lower but I also had a 6ft bed crew cab so I figured it was from the extra bed weight.
VB712
Maxi_built
Va Beach
Mine is 6'4 crew cab 4x4. It bugs the crap out of me because I can see the difference. I figured it might be from the gas tank being on the driverside.
Take a tour around your local dealers lot with a tape measure,you'll find a lot of the 4X4's don't sit equal side to side even when they're new.
WiSH2oo0
MN
2017 1500 Express 4wd RCSB
Did you leave the Zone UCA on?
14blackouthemi
North Jersey
Specs?? 4x4? Sits perfect!
Thanks.
It's a 4x4. 305/45r22's
Ground force 2in front springs trimmed a 1/2 coil off.
Belltech 4in rear drop kit. With 3/4 spacer and airlift bags. (I didn't want to rear to squat, and I like a slight rake.)
Now I'll start getting sway bars and all that stuff.
WiSH2oo0
MN
Are those Mopar vent visors 14blackouthemi and if so how close do they match the black paint? My are going to be here on 2/14.
Thanks
14blackouthemi
North Jersey
Thanks
They are avs. They are like black. Plus the windows are pretty dark so I think that helps.
DoorGuy
Glendale, AZ
2014 2500 4x4
Looking for some help on lowering my new work truck. Its a 2014 2500 4x4 crew cab with a long bed and the 5.7 hemi. I do garage doors for a living so the truck has a rack on it and being able to easily reach it would be nice. I've been looking and can't find much if any options for lowering kits. Didnt know if anyone had an idea of what might work or would be needed. I'd like to level it at a minimum but a 2-3in overall drop would be ideal. Thanks in advance for any help or advice!
IanL
5.7 Hemoi
Looking for a 2/4 kit for 2017 1500 4x4. No one has one. Would it be the same as the 2016??
charonblk07
Calgary, Ab
F1-A forged 349ci
Spoke to Belltech they wont warranty it
Belltech doesn't make a 4wd kit. You need either the McGaughy's Deluxe kit w/ spindles or the Ground Force kit. McGaughy's doesn't list theirs for a 4wd, doesn't mean it doesn't work
charonblk07
Calgary, Ab
F1-A forged 349ci
I believe the only way to bring the rear down on the 2500 is with air bags or cutting the factory springs. I don't know anybody that offers shorter springs for the 2500 4-link. I would recommend air bags so it can be a dynamic height and can compensate for increased weight. A WirelessOne compressor kit would be cheap enough and with an AirLift 5000 bag you'd be good.
IanL
5.7 Hemoi
Do you know what part numbers? Is there anyone that has done a 2017 4x4 yet on this forum?
predat-r
4.7 v8
So the Belltech kit rears should work on my 2012 awd just need lowering springs from Groundforce in conjunction with oem shock?
Sent from my SM-N920P using Tapatalk
Ftank
