Strictly the 4x4 lowering thread...
jdanruby
SE Iowa
2014 reg cab 4x4 long bed
Hey all,, I'm new here,, I just bought a 2014 4x4 Tradesman, Reg Cab, Long bed, 5.7 Hemi, I'm going to drive it as is until the snow melts then it will be time to make it "my own",,, I'm planning on a set of 22" rims and nothing less than a 2-3 drop... Ive been reading about several options for lowering and just like others on here I'm looking for opinions.. I don't want to do anything that would limit towing capacity and I still want to be able to haul 6-800lbs in the back without any problems... please share your thoughts about what looks good, rides good and still performs as a truck....
Thanks; Jeff
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
Anyone else with pics of a GF kit installed on a crew cab? Are you guys seeing only a 2/3 or a bit more drop in the rear as I've read a few guys say its closer to 4''?? Thanks in advance..
BrBlack
Calgary Alberta
When I installed the GF kit my rear ended up being 3.25" lower and the front settled to about 1.8"
I did intsall some helper bags to soften the ride a bit.
CMil527
Old Bridge, NJ
:favorites13: thank you for the feedback!
R/T_Fire
Pleasant Grove
New to me 2011 R/T.
Hopefully pic shows up. not really set up to post pictures it seems
jdanruby
SE Iowa
Thanks; Jeff
Ok,,, I've been reading and it sounds like it's down to two options,, the McGaughys Part# 44050,, or the Ground Force Kit #9983,,, I know one is less money than the other but what difference does that make if your not happy with the finished product,, I don't like how the McGaughys kit reqires the rear bump stops be cut off, and I "think" that the Ground Force kit should have a rear track bar relocate bracket.... Please share your thoughts...
charonblk07
Calgary, Ab
F1-A forged 349ci
The McG's kit is a 2/4 drop and the GF is a 2/3 drop so you still maintain a bit of rake with the GF kit. Trimming down the bump stops isn't a big deal at all, they stick out of the bracket 3.5" so it's not like you'd be losing much by trimming them down 2". You definitely want them cut down or you'd only have 1.5" of travel before you'd hit them which is very uncomfortable for daily driving.
Etroze86
Grand Forks ND
Just did the ground force kit on mine and couldn't be happier with the results.
N1ck
Regina Sk
No pictures!? Glad it worked out for you, what drop did you end up with?
Etroze86
Grand Forks ND
Im working on getting pics up but I didn't have tons of time to do the install and forgot to take initial measurements.
Etroze86
Grand Forks ND
Working on the pics just getting slammed at both of my jobs right now.
mojoe
Southern Maryland
Went ahead and dropped the back of my QC this afternoon. 30 minutes tops. Going back to 20s this summer.
mojoe
Southern Maryland
Chopped the rear. I woke up this morning and wanted the rear down. I will be ordering 2" drop springs in a few weeks. Just got bored and didn't feel like waiting
Etroze86
Grand Forks ND
OK guys finally got some pics of the drop done. I don't have starting measurements but I can say this. I love the tiny bit of rake I get from the 2/3 drop compared to just 2" in the rear. First pic is just 2" and second is the 2/3 drop.View attachment 46859
JustinRam1500
