What could this sound be
hemipower95 2.0
I hear it every day I turn the truck on, and when I turn it off. The sound stays on longer, I just recorded a small portion.
https://youtu.be/YDTd8K5k4JY
sbarron
Wasilla, Alaska
You collected a woodpecker in the HVAC system!!!
How big are you? Seat creaking?
Seriously though, it sounds like a sticky actuator somewhere in the HVAC system. Whatever one closes when the truck is shut off.
dmuney
5.9L HO Cummins
Either a blend door actuator , recirc door actuator or a mode door actuator some require dash removal some do not
Bfazona
Harmans, MD
I think it has to do with the recirc in the hvac. I get it from time to time
Hemi395
Cape Cod MA
Definitely sounds hvac related. Hopefully its not the recirc actuator because I believe it requires pulling the dash to replace...
TerraNewf
NL, Canada
i get the same sound periodically . No pattern to it
MANual_puller
Shade tree grease monkey
Vinton, Iowa
2011 Moose
5.7L hemi
recirc door is the easy one behind the glove box, blend door is harder because there's less room, mode door is the hardest.
easy way to figure out which one it is is to try one at a time. Poke the recirc button with the key on acc and fan on 1. no noise move to blend door by turning the temp knob up and down. no noise move to mode door changing where the air comes out. no noise then and it's not one of the hvac doors.
thrashie
All Over
2013 2500 Laramie
6.7l cummins turbo diesel
mine does the same thing too, my previous '13 1500 didn't.
RamCares
n/a
n/a
Hi hemipower95,
If you decide to visit your local dealership for further diagnosis I'd be happy to follow up with them for you if needed! Just PM our page and let me know.
Andrea
Ram Social Care Specialist
