What did you do to your Gen3 today?
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
I'm throwin' in the towel, this noise is literally IMPOSSIBLE for me to pinpoint. Any suggestions?
Ball joints, tie rods, front shocks, along with the sway bar links and bushings are all in new/good shape
Check your shock and check the control arm bushings
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
To be clear, I'd assume you mean bushings that hold the control arm to the truck, and not the ball joints right? I'm quite new to the suspension world lol
I was gonna say the bushing as well or the isolator maybe
I don't really know what an isolator is or where it would be located, but I'm gonna check out the bushings sometime soon. Yesterday I was looking and where the control arm connects to the truck (I assume thats the bushings you guys are talking about) still had grease, but were covered in dirt, grime and other disgusting things. One day I'm gonna have to take the wheels off to give it more of a cleaning because as it stands I can't tell how worn those things are. Knowing how much on the front end has already worn out and been replaced, I'd bet they're in bad shape
Thank you guys
Jerseystyle
Thank you guys
Greasy or dirty doesn't matter, just look for excessive wear. Take a prybar under there and start manipulating your control arms and all the other suspension bits. You should be able to figure out if they're worn out or not pretty quickly.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
I looked up videos and pictures and I know I was in fact looking at those bushings yesterday lol
I would've tried to a better look yesterday to solve this issue but my time table was narrow. I did take a flathead screwdriver and tried to clean them out as best I could, just from doing that I think its time for replacement. On both sides, the back bushings were completely covered in multiple layers of dirt and the front bushings were much cleaner, but I could tell they were worn out.
Does anyone know how difficult and expensive these are to replace? I've been saving up for an exhaust system but I think a quiet stock exhaust without squeaks is better than a V6-level exhaust with squeaks
Jerseystyle
If you're going to replace I'd get all new control arms that have new ball joints and bushings already installed. Overall price will be more but it will save you a lot of headaches.
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
That works out well because the upper ball joints and the control arm bushings are the only two bushings/joints that I haven't replaced on the front end. Everything up to this point have needed replacement, the upper ball joints look to be in okay condition (for now) but might as well go on and replace them and knock out two birds with one stone
Demon-HeMi
Houston
Goodbye Hellcat style red key and hello new flip key, my 3g is getting all kinds of fancy lol
Dont mind the extra pad there, thats the tailgate opener
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
Few days ago my sister got a new car, a '15 Honda Civic. I can't believe they STILL make cars without automatic lights standard. Anyways driving it was just a lot of "meh" for me, but she seems happy so thats what matters. Imo, the CVT-type transmissions they put in these cars destroyed any of the fun I would probably have with them. You can put as many technological goodies in these vehicles as you want, if I can't enjoy driving it, I'm not gonna like it
To say I was happy when I fired my truck up later is an understatement
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
New headlights for both mine and the wife's they were turning yellow went with the black lights instead of the factory chrome on mine
Grey ram is looking ******* already. It's the little things that make a big difference.
Anything else you doing to it?
Sent from my magic 5-inch
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
Amen. CVT's suck. That civic would actually be fun with a stick. At least a normal auto...
Gary krk
Mid Atlantic
Slagwagon, if there is enough of the original bolt protruding from the block. Run a thread cleaning die down the nowastud.. Then spray liberally with some Zep 45 and let sit for a "while". Then clean, and run the correct size but on the end of said stud and puddle weld it on. Remove with a small impact wrench. The quick heat normally breaks them loose..
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
We saw some of those Civic Si trims, That was her first choice because she loved the look, I'll even admit those things look pretty dang cool. But I guess they only put manual trannys in those things, and shes never been much of a stick-shift kinda person. With the amount of driving shes gonna be doing, auto was the better choice
With that said, if I got my choice I'd be picking up that purple 6.4L charger or the black 6.4L challenger I saw at those dealerships. It'd be fun to dust some ricers at the traffic lights
02ramboi
live oak florida
4.7 v8
So my ac on driver side is blowing week and on the passenger side hardly coming out at all any ideas on what it could be
