Ok a lot to unpack here. Got the passenger front side installed today and ran into a few unexpected problems, most due to the aftermarket lift kit.
Here’s the before:
The stock UCA was a nightmare to get off. I saturated it with liquids wrench over the 2 days leading up to the install and still nothing. Dont bother with a ball joint removal tool because ours arms are too big for them. I ended up using a pickle fork and that finally did the trick. Just make sure you have one that’s thick enough. UCA comparison below:
I had the same issue with the tie rod. Again, pickle fork and some force got it done.
Tip #2: have a buddy or spring compressor and pry bar handy. I don’t know if this was because of my spacer but getting the strut over the lower control arm was a royal PITA. I had a buddy shove down on the lower control arm to get it free.
After everything was out I got the new strut in:
Comparison below:
And here’s where it got tricky. When I put the new UCA in and jacked everything up to “road height” the control arm jammed into the reservoir. Due to the angle the UCA sits because of the lift, there isn’t enough clearance. I had no way to frame mount the reservoir, so what I ended up doing was flipping the reservoir mount upside down, cutting away some of the fender and mounting it to the upside down mount for more clearance. See below:
Got everything tightened up and here I found my biggest concern.
Unlike the stock UCA, the ICON is not threaded all the way up to the top. When I tightened the ball joint down, I reached the end of the threads, and if I pushed the UCA down, it would leave a small gap between the nut and underside of the knuckle. I don’t know if this is part of the UCA design, or because it’s an aftermarket knuckle and it’s not OEM thickness at the top of the knuckle. I will try and get a picture when it’s light. So that was my one big area of concern.
I’m going to try and get the other side done tomorrow and will let you know if there was a difference in lift height
