Southbay
- Joined
- Apr 1, 2020
- Posts
- 41
- Reaction score
- 12
- Location
- Long Island, NY
- Ram Year
- 2013
- Engine
- HEMI 5.7
I'm sure someone here has put them in. Just wanted to see if there is anything different procedure wise from installing a stock height replacement strut? Obviously I won't have to take a strut apart to re-use the spring, but as far as things to take off to get the new strut in.
In looking at it, looks to me like brake caliper and rotor come off, knock apart the upper ball joint and possible the tie rod, anything else that would need to come apart? Someone had mentioned to me pulling the axle out of the hub, but I don't see why that would be necessary. Seems like having the upper ball joint and tie rod apart will give me enough flex to get the longer strut in.
Also any helpful tips that anyone has come across when pulling struts out of this gen truck would be appreciated. Probably doing them in a week or so.
Thanks!
Thanks!
