I have a question since I haven’t looked into it much. I know the eco diesel fan motor is designed differently. It’s actually brushless and runs on an outside bell instead of an inside stator which is part of the reason it’s such a huge gain and higher cfm flow. The motor is quite a huge power increase over the v6 fan due to that characteristic in itself. Has anyone opened the motor up to see if it’s possible to get at the wiring and run the motor off of a separate brushless controller or is it to self contained since it has its own pwm module built in?
