I have Laramie seats everything works except from heaters did you have any heated seat module issues? @mjf6175
I have had NO heated seat module problems. I changed out my stock seats and added in stock Laramie seats. Its been so long since I did all of these mods I probably have forgotten many of the details. If you have the time, maybe search for my posts in this thread (and other threads). I did numerous mods to my 2500. I added heat/cool seats / heated steering wheel / memory seats / memory mirrors / automatic temperature control / cargo camera / 8.4 with nav / and more.I have Laramie seats everything works except from heaters did you have any heated seat module issues? @mjf6175
Thanks. I have the replacement harness which I will install when the weather gets better, everything else is already in place. I had reached out the M Grimm, but I think he was away. I am also adding the door panels with the accent lighting. I hope that I can get it all done.I have had NO heated seat module problems. I changed out my stock seats and added in stock Laramie seats. Its been so long since I did all of these mods I probably have forgotten many of the details. If you have the time, maybe search for my posts in this thread (and other threads). I did numerous mods to my 2500. I added heat/cool seats / heated steering wheel / memory seats / memory mirrors / automatic temperature control / cargo camera / 8.4 with nav / and more.
I lucked out in some mods like the plugs/connectors under the driver seat and passenger seat being already in place. Otherwise I had M Grimm make up the needed wiring harness. He is a wealth of info and makes EXCELLENT harnesses.
Best...........mike
Thanks I’m trying a new seat module Friday so we shall see . Thanks again for the input that’s why I love this place . now if it they only had an open bar here lol. Mike has made all my harnesses ! Atc upgrade 8.4 uaq upgrade and my seat harnesses! Rear camera reroute!
the first pic I had is the passenger side. the other 2 are the driver side. I couldn't get them to upload in orderNeed to see the passenger seat plug too
All 4th generation 1500-3500 seats should fit.can someone tell me what years seats will fit my 2016 bighorn crewcab?
also, can the heat modules and associated parts just be swapped into my existing seats?
The difference is 40/20/40 have the jump seat in the middle. The buckets have the center console. The mounting is the same except the center console vs jump seat. But the mounting for each are already there.may be a dumb question...
is there a difference in the 40/20/40 heated/vented seats vs the buckets?
are the mounting holes different?
or is it just the seating surface just different?
did the 40/20/40 seats even have the heat/vented option?
reason I ask is I've found quite a few at my local lkq salvage out of Laramie and they aren't killer expensive...
I guess what I mean is there a physical difference in the seating surface.. like dimensions or shape... if that makes sense.The difference is 40/20/40 have the jump seat in the middle. The buckets have the center console. The mounting is the same except the center console vs jump seat. But the mounting for each are already there.
this is the seat I currently have in my bighorn... looks nothing like the buckets on ebay
blurz.......your have the standard seats in your Ram. The standard seats can come as a bench seat with the center section (third seat) which has a backrest that can fold down or left up as a seat; and the standard seats can also come with a center console as shown in your pic. I had the same setup in my Ram, standard seats with a center console. I installed Laramie seats like you want to do.
Laramie seats also come with either a center fold down section or with a center console. In essence there are 4 combinations of seats:
1) Standard seat with a center section
2) Standard seats with a console
3) Laramie seats with a center section
4) Laramie seats with a console
All of these combinations will bolt into the Gen IV cab with the exception of Gen V 1500's which has different mounting brackets and electrical plugs.
The ebay pic is Laramie seats (year?). They could have come out of a Ram that had either a console or the center fold down section that was removed. That center fold down section is made with brackets that ties into the passenger seat and driver seat. If that center section is removed you are left with just the buckets and are the same as the Laramie seats in a Ram with a console.
Hope that helps.................
