I am not usually the first to ask this - is it a no crank/no start, or does it crank and just not start? Did it make any odd noises the last time you turned it off (or did it suddenly shut off?)
If it's no crank/no start, and the starter and batteries check good, and you're getting good grounds everywhere, and you can hear the starter solenoid click on, and the starter is drawing current (as evidenced by the electronics cutting out when you turn the key)...then it's not the starter or the batteries or a ground. This is starting to sound ENGINE or TRANS related.
I would try starting it in neutral. If it rolls over/starts, your torque converter may be locked up. If it doesn't, you've pretty much ruled out the transmission, which means it is engine related.
If that's the case, then what's the oil look like? What's the coolant look like? Will the engine roll over by hand (put a big breaker bar on the harmonic balancer bolt and try to turn it by hand)? If it rolls over that way, the engine isn't locked up so you've got to keep digging. If it won't budge, then the engine is locked up. Could be a bearing, could be something internal broken, could be hydro-locked. Hard to say without physically investigating.
If it CRANKS but won't start, that's completely different, you either aren't getting fuel, don't have compression, or your glow plugs aren't heating up enough to ignite the fuel. These could be any number of different things, but without more description from you we really can't guide you anywhere.
