Help needed....
I recently purchased a 2022 1500 5.7 v8 with roughly 45k miles on it. I love the truck due to its cab size, smooth ride and performance at higher speeds. I bought in doing what I felt was thorough research although I fully admit I am trying to build my mechanical mind in the...
So my 2015 5.7 started ticking with a bit of a knock 2 days ago . I changed the oil and there was no metal in the oil. It looked perfect, however, It was still making the ticking noise. I had to drive it 300 miles back home, so I drove in tow/haul mode. Milage was normal, temp was normal, but...
Hi everyone,
I’ve been hearing a strange noise coming from my car, and I’m hoping someone can help. The noise happens when the car is idling and gets louder if I press the gas pedal moderately. It occurs regardless of whether the car is cold or warmed up.
No DTC trouble code
Ram 2011 HEMI...
Hi Guys,
I noticed a loud knock on my engine. Immediately turned it off. It was coming from the even side numbered cylinders. I took vaulve cover off and cranked it to see whats up. Noticed that cylinder 4 stops moving after a few seconds. Please see videos.
Please advise.
Video Here.
Hello and thanks in advance for the replies. I have a 2018 Ram 1500 with the 5.7L. I bought it used with 24,000 miles and it currently has 33,000(rounding). I never noticed a sound before but recently have with the truck when I'm driving at a steady speed, if I need to "juice" it a little...
Okay guys, it's go time. I need all the help I can get! Here's the quick run-down... There are many thing I likely could have done to avoid this situation, but I am where I am. Thanks for reading. Enjoy, and let me know if you can offer any insight.
So... I've had this truck, my 2017 1500...
