air ride
  1. D
    Aftermarket air ride (air ride 5000) concerns.
    Is it normal for there to be a gap between the truck and the bottom plate of the air bags? The plate has 2 hook brackets on one side and carriage bolts on the other but with my truck sitting on Jack's, there is a sizeable gap between the 2. Im looking for a clunking noise that has been coming...
  2. D
    Deciding on Shocks to Replace Air Suspension | Offroader - Ram Rebel | Hot Weather
    Hey there, So I've been lurking here for some time trying to find an answer, but nothing so far. So I live in the Middle East (weather is pretty hot with the summers averaging 40-45 C) and have a 2017 Ram Rebel (with Air Ride/ Air Suspension). I offroad quite a lot (desert dune bashing and...
  3. Articlonestar
    Air ride replacement help
    Hey everyone! Happy new years! I have a 2015 ram 1500 quad cab with 4x4 and active level air suspension. I have had the dreaded sag whenever I park and finally but the bullet and bought all 4 new air bags and compressor with valve block. I purchased the springs from TRQ as it wasn't a bazillion...
  4. J
    air ride suspension
    ive seen one person do the full air ride on a 2nd gen i was wondering if anyone else has i wanna do full +4 to -4
  5. Visionari
    Tire size with air ride level
    Hello everyone! Looking to put leveling links on my 2020 1500 limited with the air suspension. After doing so, I want to upgrade the rims and tires. I want to do 20x12 35in tires with a -43mm offset. Will this setup fit or do I need to look at 33in tires instead? What have you guys...
  6. rickjkline
    Timber Grove Air bags 09-19 4th Gen Ram 1500
    0D1E7487-5191-4BBF-9703-7EAA9A513889 by rickjkline posted May 21, 2020 at 9:55 AM3CD86CBE-4F0E-43FF-B897-EB4CF78C51E2 by rickjkline posted May 21, 2020 at 9:55 AMA8A92115-7D41-4B25-AC4D-E634235C433F by rickjkline posted May 21, 2020 at 9:55 AM For sale Timber Grove Air bags for 09-18 4th Gen...
  7. Intense-Dakota
    '17 REBEL w/ air - Daystar Leveling + Links = UCA hit?
    I am thinking of adding the Daystar leveling kit (KC09113BK) to my 2017 Rebel with air. I am going to make custom links to match. I have read a few places where the 5th gens were having issues with the UCA hitting the air struts in Off Road height. Is this an issue on the 4th gens also? I do off...
  8. Intense-Dakota
    REBEL - Air Ride, one corner sagging
    Ever since I purchased my 2017 REBEL, after sitting for a few days, the drivers side rear would always sink down about 1 inch. It was never a big deal, until it started getting cold. Today, after sitting for 2 days in <10 degrees the rear left was sitting on the bump-stop (see pic). Since this...
  9. M
    Ride height with AlfaOBD (air suspension)
    Recently got AlfaOBD and an mx+ to make several changes to my truck, especially to the Air ride system. I created this post to centralize ASCM information and hopefully find others that are playing with the system and were successful in finding a good setting. I had a 1" drop of the front...
  10. S
    Lowering / Drop for 2017 Limited 4X4 with factory air ride
    Does anyone have experience with a drop on 4X4 with factory air ride, I am looking to lower (4/6 Drop) my 2017 Limited 4X4 with factory air ride. I have called Inez and Moe Performance. Neither have a kit (or solution) that support the factory air ride. I am looking to lower more than what the...
  11. Dubbsy01
    Question about lift vs locking air ride out at off road2 ?
    Hi everyone,I’m new to the forum! I just picked up a used 2016 1500 eco diesel with airride I wanted to put a small lift and larger tires? Has anyone just locked air ride out at off-road 2 instead of lifting? If so what was the result? Looking to find out max tire size for each option! Maybe a 3...
  12. P
    Four Corner Air Ride Suspension issues
    I have a 2013 Ram 1500 Laramie 4x4 with the air ride suspension, which has been having issues for a long time now. 1st a little history, the passenger side rear airbag developed a pin hole in it. I lost all the nitrogen from the system and it gets replaced by air drawn into the system through...
  13. B
    Air Ride Pump Fail - "Level Ride Assembly" Replacement
    Hey Folks, So I've been battling an issue for months now that I believe is finally identified and I am reaching out to see if anyone has undergone this repair. I have a 2013 RAM 1500 Laramie Longhorn I bought used in February (55k miles currently) and for months now my suspension system has...
