check engine light
  1. midnight express
    Bank 2
    I’m getting a p2098 code bank 2 on my 2014 ram 1500 express classic now I’ve looked up as to what side that bank 2 is on an I’ve now seen 2 different answers. One is saying the drivers side while the other is saying it’s the passenger side. I’m here to see if anyone can give me a definitive answer.
  2. M
    Code Scan providers
    OK, so all too often someone comes on to the forums and presents a problem, and the first guidance is for them to get a code scan and to come back with what was found. Totally reasonable and understandable approach. My question is, where is the best place to get a code scan? Just about any...
  3. S
    2025 Ram 1500 Big Horn CEL @ 1350 Miles
    Posted this in 5thGenRams forum, wanted to reference it here if some people arent in that forum as well as this one, just for awareness. I purchased a 2025 Ram 1500 Big Horn (with the standard output hurricane engine) on the 29th of June. Only had like 30 miles on it, rode smooth, absolutely...
  4. C
    AGS Check Engine Light Nightmare
    Hi guys, I know there is a few threads about this. But I'm looking for advice with my specific experience. I have a 2016 Ram 1500. I had a check engine light turn on, ran the code, and it turns out it's my Active Grill Shutters... Apparently this is a common issue with not very common...
  5. D
    DEF? Check engine light only
    2018 RAM Diesel with 32,000 miles on it. Check engine light comes on. I take it to Advance Auto for a code read. They said it was a error with the DEF - which is what I expected since it was time to add. I add 2 gallons. Asked them to clear the code they said they are not permitted to. I take it...
  6. J
    Check engine light after spark plug changed
    Truck was running fine, but was overdue for spark plug change. Pulled all of them yesterday and put new ones in. Used Autolite Double Platinum plugs gap .44. After getting all of them put back, started the truck and check engine light was on, and you could tell it was misfiring something. Didnt...
  7. A
    2014 Ram 2500 5.7 Hemi knocking in engine
    Hey everyone, I bought a 2014 Ram series with around 111,000 miles on it in Michigan (Truck originally came from Idaho as a government forestry truck) . After I left the dealership that I bought it from I loaded my car up on a car dolly and hooked it up to my truck to haul home. Well, I got...
  8. B
    Fuel Sensor Fail... should I fix it?
    I have a 2014 Ram 1500 with just under 60k miles on it. A couple weeks ago the check engine light came on, followed by a Fuel Sensor Fail warning. Took it into the shop today and they quoted me $1,200 to replace the fuel pump. I've read other threads on here where guys just fill up their tank...
  9. D
    Check engine light still on after replacing cap
    2017 Ram 3.8 L V6 120K Miles I recently had the check engine light come on, I replaced the cap and reset the code. a couple days later it came back on. When I went to get the truck inspected they said the Purge valve was bad and needed to be replaced. So I did it. Check engine light is still on...
  10. A
    Check Engine light for active grill shutters, fan always on and loud
    Hey guys, I have a 2019 Dodge Ram with the 3.6l v6. I just woke up one morning to a check engine light. I had a computer hooked up to the obd and it threw a AGS (active grill shutter) code. I pulled everything apart and the AGS along with the whole aero system seemed to be perfectly fine. I...
  11. M
    Lightning bolt and check engine light
    2017 ram 1500 3.6l v6 Check engine light with codes P2172, P0108, P0175, p0172, p1dd2 RED LIGHTING BOLT!!! I’m looking for any suggestions to help fix this problem, thank you so much to anyone who decides to reply, I’m new to the forum and happy to be here! Thanks
  12. Williamw
    Check engine truck bogs out m
    Check engine came on slowing down for a red light, green came on and when I accelerated the truck just sat there and literally took 15-20 seconds to go past 4 mph and this popped up. Anyone know anything? Thanks in advance. Also throws a modulator something code.
  13. M
    Check Engine Light cause and effect
    I have a question about how the CEL effects the engine and not so much about the cause: Cause - I had a supercharger and exhaust installed recently and they had to remove the Active Shutter Grill to fit the intercooler. Shortly after I got my truck back I had the CEL. It was P1D73 which...
  14. K
    P1DBD
    Hi every one I have a 2015 Ram 1500 5.7 with an 8 speed. About 6 months ago I replaced the fuel sending unit because the original fuel level sensor went out on me. Shortly after I got a new code pop up P0463 if I remember right, so I replaced the fuel pressure sensor. About 3 months go by and no...
  15. B
    '18 ram 1500 check engine light
    I had to have my battery recharged at the local auto parts store and after putting it back into the truck my check engine light came on and won't go off. I will take it to the store to ask for some help but wanted to ask if anyone else ran into a similar problem?
  16. A
    Sensors Not Ready
    Hopefully you can point me in the correct direction. I have a 2008 Ram 1500 Laramie 5.7. Last year I had a check engine light and it turned out to be EVAP System. I took it in for repair after trying the usual things (gas cap, new gas cap, etc.) Turns out there was a leak in a line that was...
  17. rubes7202
    U11E9 Error Code will not go away - AGS
    Hi All, So I keep getting this stupid U11E9 error message. I took my truck to the dealer and they tested the Active Grill Shutter and it worked fine. They cleared the codes and sent me on my way. 24hrs later the same error message is popping up again. So I am taking it back to the dealership...
  18. RustyRamFan
    TroubleShooting Electrical Codes
    Hey guys, I got a 1991 Dodge Ram 4x4 with a 318 engine and a 241D automatic Transmission. So I dont know nothing about electrical troubleshooting, and I'd like to learn alot more. I don't want my truck to blow up! Plus the ladies dont like seeing check engine lights, I think it ruins the...
  19. B
    ETC light came on, then my truck stalled out
    My 2010 Dodge Ram has had a check engine light on for a few weeks now. The other day it started acting weird and I noticed the ETC light and battery indicator were flashing. I pulled into a gas station to investigate and the engine started smoking. I popped the hood and noticed the engine...
  20. K
    Check engine light but no related codes
    Hello. I just bought a 2016 Eco diesel in December with 38k miles on it. About a week ago, maybe 10 days now, my check engine light came on so I swung by an O'reillys to get the code read and their reader couldn't pull up any codes. It showed that the check engine light was lit up, but couldn't...
  21. jlyalls
    2012 Ram 5.7L Replaced OCM but code still shows up after unhooking battery
    Hey guys, I started getting a check engine light and had Autozone scan for me and it brought up certain codes that suggested the OCM (Oil control module) needed to be replaced. The truck has roughly 134,000 miles. So I removed the intake manifold and replaced the OCM with a newer one. You...
  22. RamItFaster
    Check Engine Light
    Have had this truck less than 2 months and only put 3,400 miles on it. Already a frickin Indicator. What's worse for me is there is no code or "Message" on my dash, so I have no idea how to Reset it to see if it comes on again, any tips???
  23. R
    Fault Code U4121
    I can’t find what this fault code is but I think it’s linked to the following symptoms: When it starts and it's cold, the symptoms are: • Windshield wipers constantly running at normal speed: not adjustable or stoppable. • Steering wheel controls don't work. • Seat heaters don't work. •...
  24. rubes7202
    Getting a P2016 error Code after running Pedal Commander?
    2015 RAM 1500 SPORT 4X4. 50K Miles. I have been running the pedal commander (PC31) for a week with no problems. All of a sudden the check engine light comes on and i am getting the error code P2016. Is this related to the Pedal Commander? P2016: Intake Manifold Runner Position Sensor/Switch...
  25. V
    2019 Ram — The check engine light turn on
    Hi! Just one week after buy our new Ram Diesel 6.7 ******* motor the check engine light turning on when the tank is full. ‍♀️ Any idea??? Help!!
