OBDll SCANNER/DIAGNOSTIC/RESET TOOL
RamTough7862
Richmond Va
IF YOU OWN A VEHICLE WITH A COMPUTER IN IT AND DO MOST OF THE WORK ON YOUR VEHICLE YOURSELF. RESEARCH WHICH "OBDll" SCANNER BEST FITS YOUR NEEDS TO SCAN, DIAGNOSE & RESET KEY COMPONENTS ON YOUR HOT ROD. >>> IF YOU JUMP ANOTHER VEHICLE VIA JUMPER CABLES, YOU CAN SCREW UP YOUR COMPONENTS IF THERE'S A VOLTAGE DROP. >>> IF YOU UNHOOK YOUR BATTERY CABLES, YOU CAN SCREW UP COMPONENTS LIKE THE AIR/FUEL MIXTURE. IT CAN & WILL RESULT IN YOU NOT BEING ABLE TO START YOUR CAR. AND IF YOU'RE NOT A TRU BLUE MECHANIC, IT COULD COST YOU $1000.'s TO FIX WHAT A "OBDll" SCANNER COULD FIX FOR YOU. NOT TO MENTION ALL THE OTHER FEATURES IT PROVIDES. LIVE DATA STREAMS, UP TO 28 RESETS. BUT YOU GOT TO RESEARCH THE MANY DIFFERENT KINDS TO FIND THE ONE THAT WILL BEST SERVICE YOUR PRIDE & JOY...
THE OBDll PICTURED BELOW I PURCHASED FOR MY 2003 DODGE RAM 1500 5.9 SLT. $388.00/$52 4 YR WARRANTY THROUGH A POPULAR ONLINE RETAILER. #StayRamTough
stevenmicheal
