lifter failure
  1. Alkali
    Lifters?
    Hi All, So I recently bought this 2017 Ram 1500, and I didn't notice it had a tick. Its only there when the engine is somewhat cold. I did find at least one broken manifold bolt on the passenger side, so it might only be the exhaust leak. However, I notice the exhaust leak on cold starts and...
  2. R
    Hemi Tick....but lifters look fine??
    Hi guys. Coming in for some advice for my current project. My problem statement is I just tore apart my engine expecting a failed lifter....but no failed lifters to be found. So here is what happened.... I bought a 2013 Ram 1500 5.7L 4x4 Express with 145k miles on it. Owners selling the truck...
  3. Brandonc1
    Lifter failure again… how to bulletproof?
    I have a 2014 Ram 1500 that had lifter failure at 220k. When this happened, I was able to get a parts truck with 70k and swap the motors. After putting 3,500 miles on it, this engine also has lifter failure. I don't want to deal with this lifter failure again. I've been doing research for...
  4. L
    P0301 Help
    I have a 2011 Ram 1500 SLT 4WD 5.7 Hemi with 183,000 miles. These are all the codes I have currently: -P0301 cylinder 1 misfire -P0456 evap system leak (I have a small exhaust leak so self explanatory) -P0153 O2 sensor 2/1 slow response -P0133 O2 sensor 1/1 slow response -P0430 Catalyst system...
  5. H
    5.7 Hemi "blew up" by dealership?
    I have a 2015 5.7 Hemi with 140,000 miles First of all, I am no mechanic so bear with me. Bought this truck new in 2015, serviced regularly and never had a single issue until about a month ago. The malfunction indicator light came on and I noticed I was getting approx 2.5 MPG less than normal...
  6. MarcoFuc
    Is it a lifter failure?
    So I have a tap/tick after camshaft and all lifters replacement along with a new oil pump “+10 psi above stock. And timing chain. But this tick only occurs when the oil temp is 180-200 degrees. And only at idle and soon as you add the slightest Rpm it disappears then returns once the rpm drops...
  7. C
    Need help truck keeps ticking!
    I have a 2007 dodge ram 1500 megacab non mds and I’m stumped on what to I’ve gone through the entire top end of the motor. I started by doing my lifters, exhaust manifolds and new plugs and all new gaskets (made sure to clean everything) and my truck was still ticking so then I thought okay...
  8. B
    MDS Pulse when going 4 back to 8
    The MDS system in my '14 1500 5.7 seems to be "fluctuating" when it shifts back to 8 mode from 4 mode. I can feel it in my pants and hear it. I confirmed this by shutting MDS off by using the gear selector on the steering wheel and the issue went away. I have AlfaOBD so I can do some in-depth...
  9. H
    Piston slap?
    So I have a 2013 ram 1500 5.7 hemi, I replaced the manifold which was ticking and then there was another tick so I brought it to the dealer and they said it was an internal engine noise, a piston slap. Said the pistons are slapping up to the cylinder walls. I figured bringing it in there that it...
  10. A
    Good Times A head...
    Hey guy I'm Adrian... Just bought a 2013 Ram Quad Cab Sport Hemi 5.7L... Has propane conversion kit (hybrid)… Coming from Fords I've done some wrenching before... My buddy made me an offer I couldn't refuse... There's a catch... it has a misfire on cylinder 5... :) ya... a lifter and cam...
  11. J
    Lifter tick after cam and lifter replacement
    I've got a 2010 ram 1500 with the 5.7 Hemi. I had a lifter failure that destroyed one of the lobes on my camshaft and caused a misfire on cylinder 5. I have replaced the camshaft, lifters, oil pump, had the heads refreshed, and verified that none of the push rods were bent. That fixed the...
  12. B
    Should I change the lifters now?
    Okay guys, I have a 2014 Ram 5.7. This truck was my best friends who died of heart attack, I will never get rid of it. I know these trucks have lifter failures, so if you had the money would you change them to the Hellcat ones now or do I roll the dice and just know that I’m taking a chance...
  13. R
    Cam n Lifter Job
    Lifter seized up on #5 looking for a list of all applicable parts including non related parts i should be replacing while im in there, that i will need to complete this job. Here is what i have so far in my cart. - Cylinder head bolts - Head gaskets - Manifold bolts - Manifold gaskets -...
