lower control arm
  1. T
    Lower Control Arms
    Replacing my lower control arms soon. In all of the videos I’ve seen of them being replaced the whole knuckle was removed. Is this necessary or can I get away with unbolting the lower control arm from the truck, knuckle and strut. I’ve replaced upper control arms myself but never lower control...
  2. Waterfowler41
    How to: Install Core 4x4 Rear Lower Control Arms
    The following is a quick walk-through of how to install Core4x4 lower control arms. Even if you are just replacing like for like, this walk through will apply. I installed some fixed length lower control arms on my 2020 Ram Rebel the other day. These will beef up the rear suspension and...
  3. Mvansciver
    2012 ram 1500 cv axle and lower control arm trouble?
    2012 ram 1500 4x4 So im currently replacing lower control arms, driver side was fairly easy and everything came out without an issue, now the passenger side rearward lower control arm bolt will not come loose out of the bushing. Ive smacked it for hours with a 4lb hammer with no luck. The...
  4. Mvansciver
    6” Lifted Ram 1500 New Strut Question
    I have a 2012 1500 with a 6” zone lift kit with 35x13.5x20 toyo rt’s. I just replaced the lower control arms with moog arms that have new balljoint and bushings pre installed. I also am replacing my stock strut that has the lift spacer on it with rough country n3 pre loaded struts for a 6” lift...
  5. M
    Needing to adjust Cam Bolt. Lift on Axle, Frame, or Lower Control Arm?
    First time posting and could not find the answer anywhere on the internet. So this must be an easy one for everyone, except me, haha. I have a Stock 2016 RAM 2500 4x4 6.7. Needing to adjust the cam bolt (upper and lower) on the passenger side lower control arm. My question is where do I put the...
  6. pjschu55
    Bent Lower Control Arm
    Guys, need some advice/help. So i raised the front end on my 04 Ram 1500 4X4 with a 2 inch level kit (torsion keys) and the rear with 2 inch blocks on the leaf springs and it looks great. Ever since then ive been blowing out cv boots (minor tears really). When i got the truck i slid off the...
  7. K
    Lower Control Arms/LCA Skid Plates
    I've done some deep googling and forum hunting and come up with nothing. I understand that our stock LCA angles dont need any correction with adjustable struts, but cosmetically/lust for overbuilt gear has me hunting. When I get my prerunner bumper on, they are going to be exposed for everyone...
  8. Jmwarix
    Bent Lower Control Arm Mount
    Hey guys, I'm hoping somebody has run into something like this before. I recently bought an 07 Quad Cab at auction, and didn't realize the extent of the damage until after I won the bid (since you can't drive the vehicles before bidding). The previous owner ate a curb or something really hard...
Carbary
