I’m looking for anyone with any experience doing a cam and lifter replacement on a lifted 1500. My 2015 4x4 is lifted 4” with a kit from rough country and it’s going to need a cam and lifters at some point soon. I’m most likely going to swap to a high volume oil pump with non mds lifters and...
I just ordered a “new” 545rfe transmission for my 2009 ram 1500 5.7, used but it’s been tested and everything. I know I should change the filters and pan gaskets in the new transmission, just wondering what else I should replace before I install it. And if anyone has any tips it be much...
My 2019 Laramie Sport has 9000 mi on it. I had the dealer change the oil at 4500 miles and I decided to do it myself at 9000 mi. I'm glad I did because I found corrosion around the plug hole and the plug gasket melted to it. Also spots starting farther up the pan. Pic attached. This has only...
hey all, good to be here(finally), I have a 2011 4x4 1500 laramie 5.7 hemi that needs a new oil pan. I recently read a thread on an 04 with a magnum that had pretty clear instructions on how to remove and replace. I was wondering if the same procedure is done on my truck or completely different...
I have a 2009 Ram 1500 5.7 4x2 with 214k miles. My oil pressure is steady at 30 until I punch it and it loses all pressure. Only gains it back if I let the engine sit for a couple minutes and then it retains I'm believing it's sludge buildup in the bottom. How do I drop the oil pan so I can...
