radio problem
  1. B
    7” Screen not working - 2013 1500 Big Horn
    My stock UConnect LCD screen has mysteriously stopped working. I started the truck, saw the LCD screen start to boot up properly, but then it flickered and then went out. It’s been displaying nothing ever since. Checked the hidden radio fuse, it’s still good. Disconnected my negative...
  2. dehdlee Duo
    Stereo is now not working after Heater core replacement
    Hey all, I have so many questions but one thing I wanted to find out if anyone else has dealt with this problem. I took my truck in to get my heater core replaced manily cause I don't have a garage and didn't want to be in the cold to tackle that. Anyway I would like to find out if I may be...
  3. H
    Radio has a message of resource file load failed
    I have no idea how this happened I just started my truck up as normal and I saw a black screen with the message "resource file load failed" on the screen. The backup camera works fine but I cannot access anything on the screen I can change the volume to the radio only. what caused it and how do...
  4. S
    Radio problems
    So I was heading home from work and the radio suddenly cut off. Tapped it a few times and nothing. Started playing around and found that my satélite radio worked, just not my fm/am. Didn’t think much of it, looked some stuff up and thought it to be a fuse. Got home and checked my fuses and they...
  5. R
    Replaced Radio but still doesn't work
    My radio random got bars on the screen and the audio stopped working. I pressed screen off and it would never come back on. Every now and then it light up with the black screen for a second but nothing more than that and if I didn't drive the truck for a couple days the battery would die. I've...
  6. M
    Help With Touchscreen Radio/Kilometers to Miles/Replacement
    Hello Everyone, New member here. I have a situation that I have spent a lot of time researching and could really use some assistance from anyone knowledgeable out there! I have a 2014 RAM 1500 Bighorn with a 5" touchscreen. A couple of months ago, the screen got stuck on the RAM logo Splash...
  7. TomRF
    2020 Ram 1500 Laramie with crap 12” U-connect
    I’ve seen other threads with people who’ve had issues with the 12” U-connect screen. As of now, I have 17k on my truck. I’ve taken it to the dealership 14 times starting at 1250mi all the way through 14.5k mi. They swapped the radio out twice and replaced the original radio with two refurbished...
  8. B
    2014 8.4 nav, dog chewed up volume knob
    So my dog chewed up the volume and AC knob, they still work, just look ugly, anybody know of a way to replace just the 2 knobs rather than the whole faceplate that has all the buttons and knobs? Thanks
  9. Toretto Johnson
    Uconnect 5.0 Problem
    My 2013 Ram 1500 radio froze. How do I rest the uconnect 5.0 radio,?
  10. R
    Audio
    At random times my radio will make a popping noise then no volume will work. The rest of everything is fine I can switch am fm satilite and CD but no volume on anything volume bar won’t even show. I have a non touch screen in an 2011 slt. Sound goes off and I turn truck off for a couple minutes...
  11. R
    Radio popping noise then no volume
  12. F
    Navigation not working correctly
    2017 Dodge Ram 1500 My navigation has not been working correctly for some time. I have brought it into the dealer and they have updated the system both times. Here are the problems: 1) The voice commands do not work correctly. I tell it to find an address in Florida and it tries to take me to...
jimn
