chris032188
Is it possible to get the PSI reading on here via a reader? Or does the ecm just detect that it has pressure without a psi reading?
With a proper scan tool or even a half decent scan tool will display the oil pressure. The 2004 PCM receives the input from the oil pressure sending unit.Is it possible to get the PSI reading on here via a reader? Or does the ecm just detect that it has pressure without a psi reading?
Having trouble with oil pressure?Is it possible to get the PSI reading on here via a reader? Or does the ecm just detect that it has pressure without a psi reading?
Supposedly this is true on Ford trucks, but that does not mean it's true for all manufacturers.Oil pressure is not real. Saw a video on this 2 days ago. It's part of the ECM programming. The oil pressure sending unit is actually just a switch. The ECM does some math with the RPM and adjusts voltage to the gauge accordingly. Dude reprogrammed it real time and changed the behavior to show his work. Blew me away. I've added a mechanical oil pressure gauge to my list of to do's.
I am thinking it is after 04/05 where you can read the PSI. I tried my snap on scanner, my MXLINK, and my buddies autel. We could not pull oil pressure.Supposedly this is true on Ford trucks, but that does not mean it's true for all manufacturers.
In the case of Ram trucks there's evidence that this is not true. In this forum alone there have been a number of comments that changing the oil viscosity alone has changed the indicated oil pressure. If the claim was true every Ram owner would be recounting the same pressures at speed or idle at various temperatures.
Secondly, many of the diagnostic procedures in the service manuals will have a technician read the oil pressure on a diagnostic tool that is connected to the OBD port in the vehicle. This can only rely on a system that utilizes a direct reading sensor.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 142455 miles.
Many PID's on scan tools are inferred, and have gone through a labyrinth of electronics and data filtering/conversions to display what they do.Is it possible to get the PSI reading on here via a reader? Or does the ecm just detect that it has pressure without a psi reading?
Yea I ordered one, I'm waiting for next oil change to install itI’ve been adding mechanical oil pressure gauges to all of my personal vehicles for as long as I have driven.
It is the best way of getting an accurate measurement, and worth the investment.
This makes me feel good on long trips , glancing at the pressure gauge and knowing it’s true.
