05 ram 4.7 high miles maintenance
AaronDoesntCare
I have an 05 Dodge ram 1500 4.7 magnum Rwd it's the base model ie no power windows or locks etc.. the truck has 226124 miles I just wanted to know what should I prepare for or what should be done to keep the truck running strong I use this truck to get back and forth to work and work out of town mostly and don't want to be stuck on the side of the road
AaronDoesntCare
AaronDoesntCare
I haven't the slightest clue all I know is what I was told about it....so I'm just gonna go at it like nothing has ever been replaced. I dropped the transmission pan because it had bubbles in it and it still had the factory screw on filter (looks like oil filter) I've replaced tps sensor both cam/crankshaft sensors some new plugs bought a new belt tensioner just haven't put it on yet the truck looks like it was taken care of at some point but that some point passed and then I got it after it was abused a little bit ... I know it needs 1 wheel hub so ganna replaced them all along with inner/outer tie rods and other front end parts that look worn
