07 ram 1500 hemi 4x4 tow 4 wheels down
Bud404
Can I tow an 07 ram 1500 hemi 5.7 4x4 with all wheels down?
How? Put the 4WD in neutral and the tran in neutral?
Thanks
quietpeen
2021 TRX
Hellcat
I don't know what you mean, but hopefully somebody who does will chime in soon
lol....it just hit me what you meant, I still don't have an answer though...LOL
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Does your truck have the manual shift for the 4x4 or is yours electric? These truck are sopp to shift into 4 high under 45 mph rolling. Only time you will need to bump the trans into N is when your trying to select 4Low. When doing 4Low you will also need to be on fairly level ground and helps to keep your foot on the brake. Hope this gets ya started.
Musclemckeester
Houston, TX
n/a
n/a
I'm assuming you mean tow it with all 4 wheels down....as if say you're towing it behind an RV? If so yes, once it's hooked up, neutral on the 4x4 and neutral on the trans.
TheMaddog
DFW
If your towing it, put it in neutral. If your pulling something, I would just start out in 4 high. Save your self the trouble with gas and use that.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Ah hell guys thanks I was not thinking of towing the truck behind something... need more caffeen
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Diesel fumes in the shop dont have me thinking lol
HemiBabe
DFW
lol i was a lil lost too
B
Bud404
Thanks a million - and sorry I should have been more clear that I meant pulling the truck behind an RV with all the wheels on the ground.
I sure appreciate it.
HemiBabe
DFW
It's ok lol, I'm glad you got it squared away :D
