Gamester
- Jun 23, 2016
- 466
- 111
- 2016
- 5.7L Hemi
Which size longtube headers, 1-3/4 or 1-7/8, would give more overall TQ/HP for a supercharged 5.7L Hemi?
1-3/8"?
1 7/8 have proven gains, but I hate to be the party pooper, but there is a large difference in a NA 5.7L and a SC 6.2 LS build. Your talking about moving quite a bit more air and fuel and about a 200 horsepower difference. So I would t look to deep into that post when comparing them to a ram
Gamester, are you trying to build a dyno queen or a truck that actually performs on the street/track? Supercharged or not, if you are making 470hp and cant spin a tire off the line, then the last thing you need is a large primary header that is not going to show its potential until higher in the rpm range.
Yes, there are trucks running 1 7/8" headers and run very well, but these guys are at a much lower elevation and are racing their trucks...they had no problem breaking the rear tires loose even when they were bone stock. Unless you are building a dyno queen, I still feel like you are making the wrong choice on these. Doesnt matter if a motor is supercharged or not, the larger the primary is, the higher in the rpm band the power is going to come on. At your elevation, you need low rpm tq, not high rpm hp.
Hmm, dyno queen huh? So, you are saying that the tool that performance enthusiasts have been using to measure power output for decades has no "real world" correlation? Sorry, but that doesn't make sense to me friend.
A dyno just measures the real power output that is put to the ground. I have shown you a couple of examples of dyno charts that prove that 1-7/8 primary headers do in fact produce more low RPM torque and HP than 1-3/4.
Therefore, 1-7/8 headers would be a more logical purchase for low-end as well as overall gains. Not sure how you can dispute against an actual measurable difference like that...
This post was comparing to an SC 6.2 Vette around the same power level, not that BB motor from the other post, so you may want to take a read through that; but I know what you are getting at.
Still though, I'm more inclined to believe a dyno than someone's opinion; it's just the way I'm wired being the technical guy I am. I didn't take offense to the dyno queen comment, I just find it odd that you don't consider dyno numbers applicable.
If you do have any dyno or 0-60 times or some kind of numbers on these trucks in particular comparing the two primary sizes performances, I would be interesting in seeing those however.
Thanks
