1/4 times on Nitrous
Budakane
Northern VA
345ci Hemi
I am building another project: 2006 QC/SB Hemi 2wd. What can I expect to run on a stock truck and a 125 wet shot?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
On a completely stock truck with a 125 shot, you are looking at high 13's with traction.
Budakane
Budakane
Northern VA
345ci Hemi
Thanks Matt!!! That helps a bit, now to decide on Longtubes vs Cam.....I only have enough for 1
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Are you building this just for the track?
What gears do you have, and does it have a limited slip out back?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
My advice is to start off with a set of 4.56 gears, a 3000 stall converter, and some sticky tires. You will gain much more from these than you will get from headers or a cam.
Budakane
Budakane
Northern VA
345ci Hemi
Gotcha, I see myself going in the same direction as my last build...lol. This truck I'm not afraid to break, so I can use my DRs i have in garage. What about 4:88s?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
4.88's will probably be to much gear with the nitrous. You want to cross the traps at the top of 3rd, and I think 4.88's would put your into 4th.
Budakane
Budakane
Northern VA
345ci Hemi
Gotcha, makes sense. You have been a great help Matt. I will be hitting you soon for gears. I'm going to install nitrous in the Killer Bee also, but going to keep it a show truck, and tow the other to the track..lol
ST-8
Can't wait to have another vehicle so I can have at it with my truck. I need to start piecing together my nitrous kit as well
BoBoway4
