1.5” leveling spacers Installed, now I have caster issues
stickpony
Powder Springs
Hey guys,
I just installed some 1.5” leveling spacers in front on my 2004 Ram 2500 2WD Hemi, I think the total lift ends up being close to 2 inches, although the suspension may not have completely settled yet.
I went to get it aligned, toe is perfect and camber is ever so slightly negative on both sides by like 2/100ths, but the caster is way low, and the alignment shop said the most they could give me is 2 degrees of Caster. The spec calls for 3.5 - 5.6 degrees of caster. As a result, I feel like the trucks steering is a lot more sensitive, and I don’t like how it feels, even though it rides straight.
Is there anything that can be done to help dual in the caster to be closer to the stock 3.5-5.6 degree range?
Jason G Slabaugh
Rossville Indiana
5.7l hemi
Aftermarket align parts can help, or if the upper control arms can be slotted out where they bolt onto the frame, may give you more wiggle room
S
stickpony
Powder Springs
They are already slotted out from the factory on the frame. You adjust caster and camber by shifting the UCA’s left to right and in and out
Kmiko
