Farm truck
What will this outlet run? How many amps will it carry?
Ya your pretty well stuck at not running anything more than 1 amp, your espresso machine is out of the questions, I installed a 500watt unit, peeks at 750, the unit fit right in the dash, works real nice.
Did you replace the factory inverter with the 500 watt one or just add an additional plug? All I ever run on mine is my laptop charger or flashlight battery charger but it'd be nice to have more powerful option if needed one day.
not sure about the 2014, but my 12 says in the manual that it is rated for 150w, and the breaker will flip at 180w, so you get about 1.3 to 1.4 amps out of it. I used it to run a dremel while trimming my grille for the insert, worked like a charm
It struggled charging our portable dvd player on our road trip.
Where is the factory inverter located? can it be easily yanked out?
