120 volt plug on dash
JoshNHRA
Cummins 6.7
2014 5500 SLT.
Does anyone know a way to make the 120volt plug on the dash stay on, with the key off. I use my 120 volt plug to keep my laptop charged, but its a pain in the ass that i need to leave the key on to keep it charging.
Any input or wiring diagrams would help. Thanks.
JoshNHRA
JoshNHRA
Cummins 6.7
Nope it wont. The laptop draws very little current. In my previous truck, i ran a 400W inverter all day without issue.
jlb
MT
CTD
Shouldn't be too difficult a process, but I don't have any wiring diagrams, so no reply of mine will be simple. However, I would imagine some probing will a multi-meter would sort out a solution relatively quickly.
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
sorry not trying to hijack your thread. I have a 12V/800 W inverter and I know how much draw I can put on it but I have no idea how much draw is the in dash 120V plug meant to allow? Anyone know?
LB3711
Trumbull, CT
3.6L V6
OEM plug is 150 watts.
Sent from my Samsung Galaxy S4 using Tapatalk
jlb
MT
CTD
If I remember correctly it also says on the outlet cover.
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
nothing on the outlet cover about output wattage. but thank you for the info 150 W isn't much power.
jlb
MT
CTD
Hmm, must be an older RAM thing I guess.
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
must be. I wonder if they changed the labeling part on the newer RAMs I wonder if they changed the total output wattage as well? I wonder if that info is in the owners maunal
cgeorgemo
Joplin, MO
3.6 Pentastar
I wonder what the part number for the AC outlet is so I can add it to my Tradesman...
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
I guess you'd have to go to RAM for the part number.
I just read my last post for the first time I must have been off in wonderland when I worte that. Alot of "wonders" in the phrase:roflsquared:
Sorry to anyone who read it.:)
