Ken226
- Joined
- Mar 12, 2017
- Posts
- 2,305
- Reaction score
- 5,969
- Location
- Washington State
- Ram Year
- 2013
- Engine
- Hemi
I used to own the 2wd version of this truck, and replacing the manifold studs wasn't that bad. I did it twice on that truck.
Put it up on jackstands, remove wheels, remove wheel liners, remove engine oil dipstick tube, then remove heat shields and manifolds.
About 15 minutes center punching, drilling and ez-outing the broke studs.
Re-assemble.
Well, i did my 4x4 today. The passenger side was just like the 2wd truck. No prob
The driver side was fu@king horrible. The dipstick tube is impossible to remove without either cutting off the lower bracket, torching a chunk out of the motor/front diff mount or removing the motor.
The d/s engine mount doubles as the front diff mount, and covers the dipstick tube mounting screw. The screw, if you nimble enough to fish a wrench through a gauntlet of wires and tiny spaces to reach it, will thread out about 2 turns before it hits the bracket. The dipstick aint coming out!!
I had to remove the exhast y-pipe, which means removing 4 rust seized in oxygen sensors, and 2 rust seized u-bolt nuts. Then fighting, banging and ******* cursing to get the thing out of the way so thst i could fish the d/s exhaust manifold and heat shield out, rearward and down, alongside the transmission.
Anyone find a better way on the 4wd trucks?
Re-assemble.
