SitKneelBend
Moderator
Member Relations Specialist
- Joined
- Jan 8, 2015
- Posts
- 10,986
- Reaction score
- 7,677
- Location
- St. Louis
- Ram Year
- 2014
- Engine
- 3.6 Pentastar
Have you checked around areas that coolant goes to? I wonder if it can pass a pressure test with things like the 3-way coolant bypass in play because it seals off the leak area? IN other words, maybe the pressure test is isolated from the leak? Did they pressure test it under operation?Maybe? The pressure test should have found any leaks in heater core though. Not wet, doesn’t smell like antifreeze inside truck. Heat works.
