17 or 18X9's ? 35's w/18-20 Offset? Back spacing, Bolt Pattern Etc...
Rated R
Rated R
USA
Well from what I understand the Fuel Podium wheels are only available in a +1 offset so I'll keep looking. Thinking about possibly going with 17" Racelines through CJC. 17X9 w/ +20mm offset. The bronze color might look real good with Max Steel:
Rated R
Rated R
USA
I pulled the trigger on the wheels above yesterday. I'll probably go with the Nitto Ridge Grapplers in 35X12.50/17 with E load rating.
ttusomeone
Nashville, TN
I installed KMC XD 18 x 9 with +18 offset wheels and Toyo RT 35x12.50R18s on my 2018 Power Wagon. I love the wider stance it gave the truck. The OEM wheels and tires look way too small and sucked in.
Are you still enjoying those wheels? I know it's only been a month, but I'm trying to decide between a set of those (in the 17x9) or a set of AEV Salta's.
Joeeffinger
Katy Texas
Hemi 6.4L
I love the wheel. They balance out perfect. The offset of +18 will put the tires almost to the end of the flairs. Just enough to keep all the dirt and mud slung under the fenders. I like the 18x9 size the 17s looked too small.
ttusomeone
Nashville, TN
Thanks for the feedback. I'm definitely leaning that directly. For me it's down to the AEV Salta's or the Hoss 2 in 18s. I'm leaning towards the gray/black Hoss wheels though.
Any issues with rubbing with the 35s?
Joeeffinger
Katy Texas
Hemi 6.4L
No issue at all with the decreased offset I get zero rub anywhere. There is a ton of room now to the control arms. I thought about even going to a wider 35x13.5xR18 tire but not sure if it will fit on a 9 inch wide rim. Most people put those on 10inch wide rims.
McBroom
Denison Tx
Hemi 6.4L
The 6 spoke looks better than the 8 spokes
Blue Mule
McBroom
Denison Tx
Hemi 6.4L
How much is braking affected with larger tires or the more aggressive offroad tires?
In a 35" not as much as a 37 or 39 would be. 35's no different as stock is a 34
Blue Mule
olyelr
Kewadin MI
Blue Mule
Stock is barely 33 with no weight on them. And they are light.
When I switched to 35” Falkens, breaking and acceleration definitely took a noticeable hit. Nothing horrible, but certainly noticeable.
Mace Peveler
Canby, OR
What olyelr said. I put 35" Falkens on mine last month and noticed the same.
