180 degree T STAT
tsielski
North Carolina
OEM's use hotter T-stats primarily because a hotter running engine yields better emissions performance. How much cleaner is unknown. A hotter running engine will push engine oil temps higher as well. That issue gets compounded if one tows in hot weather. Coolant and oil temps can climb quite high. Engines generally make the most power with relatively cool water and relatively hot oil. Engine coolant in the 185 to 195 degree range, and oil temps between 180 and 220 degrees.
Installing a 180 degree T-stat will have coolant temps stabilizing in the 185 - 186 range while moving at speed. On an untuned truck, you do want coolant temps to initially reach at least 186 because if it stays cooler than that, a code may be thrown. Also on an untuned truck, sitting in stopped traffic will still have coolant temps climb into the 190's and possibly into the 200's as your e-fan doesn't turn on until coolant temps climb into the 220 degree range. Some have reported issues with the hemi shutters fighting the 180 T-stat. The shutters allegedly are for better aerodynamics, but in fact they do restrict air flow thru the radiator & trans cooler to a degree. The entire assembly can be removed if desired by performing one of two tweaks to the motor that drives the shutters. Search this forum, as there are posts describing both methods. My shutters have been removed for over 15K miles with no issues.
Some have said that motor oil can safely take consistent temps in the 230 degree range or higher. Perhaps, but motor oil is rated at 100 degrees C, or 212 F for hot running performance. Higher temps than that will cause the oil to thin, not perform as a 20 weight, if you are running 5W-20, or perform as a 30 weight, if you are running a 5W-30 as examples. The higher the temps go, the more the oil thins, and the less effective the oil is at reducing wear.
In my truck, the 180 T-stat has my coolant stabilizing at 186 degrees while underway, and my oil temps in the 203 degree range. Aggressive driving, or climbing a grade while towing my enclosed cargo trailer will force those a bit higher, but still ok. I'm happy running the 180 degree T-stat in my truck.
maitai11
Nevada
tsielski: Thank you for that well-thought-out response; my truck does not have the shutters, so no problem there. I run AMSOIL 5W-20 as per mfg spec (on the weight, not brand of oil.) I'm still deciding one whether to do this...I wouldn't want any codes thrown, although I do realize it can happen with my recently installed K&N CAI...I'll continue to weigh the pros and cons, many of which you've given here. Many thanks.
Maitai
Maitai
The trucks go into "closed loop mode" at 160,you won't throw any codes. You're over thinking this,lol
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
So got the t stat and it doesn't come with a gasket... Am i gonna need one? Truck has less than 2k miles on it
Re-use the stock rubber one that's on your OEM T-stat. Hopefully it's a 63mm T-stat,the 64mm ones are a bit harder to fit into the outlet hole with the stock gasket.Make sure you have the jiggle pin/bleed hole at the top
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
Ok was wondering if the stock one would still be usable... Thanks
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
Now for a stupid question... I want to make as little mess as possible. Would putting the front end on an incline/decline make any difference on the amount of antifreeze iIlose?
It won't hurt,also makes getting at the drain a little nicer.I stick a piece of hose on the drains nipple and point it into a drain pan to mininiumize coolent loss.
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
Which one? Incline or decline?
bassheadhemi
Montreal, Canada
I compromised and went with a 190* thermostat because we get cold winters here in New England. I just felt 180* might pose some heating issues. I used a Stant 48799 thermostat https://www.amazon.com/gp/product/B00CMN7XOY/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Throwing this out there as an alternative.
Sean did have to change my tune to accommodate it.
Even in colder climate the 180* is fine, just last night we came back at - 12*F and I had to lower the temp and remove my winter coat because it was too hot in the cab.
I had until recently a front grill cover (from an ecod) and the difference was that the oil temp was a little higher and better mpg(+1) on the highway. I removed it because we had temp in the 45*F, but 2 weeks later we get this crap again...
Sent from my SM-N950W using Tapatalk
maitai11
Nevada
Thanks Wild One...it's this kind of corporate knowledge noobs like me don't yet have - so I appreciate the distinction of codes being thrown at 160 vs 180.
I don't really think of it as over-thinking...more like passionate obsession :):):) Love my 1500!!!
Thanks again!
Maitai
Hemi395
Cape Cod MA
Good to know that 160 is the threshold for popping a code
R.L.K.
Bristol , Tn.
Thank you sir !!!!
I've often wondered why anyone would put in a 180 T - Stat ....well said indeed Sir .
It's not for me and my application as I live in N.E. Tennessee in the mountains . We only have about 3-4 months of warmer weather upper 80s to low 90s if we get to 95° people go nuts LOL [emoji16] , I've lived in much warmer states ...too funny !
I do my share of uphill towing just not enough to constitute a cooler T-stat...
Hell I have trouble getting my oil to 212° f to help burn off normal condensation 8+ months out of the year .
Thanks again for your indepth explanation Sir [emoji106][emoji106]
noraa73
