During a coolant change I swapped the stock 190 degree thermostat for a Motorad 180 degree unit. With the 190 the coolant temp was always around 194 and oil temp was 203 with out a load or my smaller trailer. I started towing a larger trailer and the temps shot up to 215 coolant and 230 oil. I was a bit concerned at the increase.
With the 180 unit the coolant temps are 179 to 181 and oil is also 179 to 181. What surprised me is that with the lower temp thermostat, the oil and coolant temps pretty much track each other. Whereas with the 190 thermostat the oil was always 9 - 10 degrees higher than coolant. Have not towed the big trailer yet but I am expecting I will see lower temps.
I live in Central Florida so I am more concerned with heat than cold.
