1987 Ram 225 Carb Issues!?
miles102
magnum 5.9
This is my first 1st gen ram, has the slant 6 3.7 I do believe, the carb or something is causing severe flooding of the engine, got the truck cheap on a deal, got it running decent but acts like she wants to stall as i come off the clutch and have to give it more throttle to keep it alive and i feel like the clutch does not like this as i am trying to engage 1st gear to start out. question is, is there a diagram on what lines are necessary for the carb to run correctly, can i find a two barrel to replace the one barrel? should i stick with the 1 barrel? so on im not familiar with this old school tech, any help would be great thank you.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Take the air cleaner off and make sure the choke is coming off when its warmed up. The choke butterfly should be open after a minute or so of running. If it is wide open but the engine is stumbling it may need a carb rebuild or it may have fouled sparkplugs or bad cap & rotor. You'd might be able to get more help if you had a video of the issue.
M
miles102
magnum 5.9
10-4 i send a video asap thank you. have you ever
