pacofortacos
- Joined
- Apr 18, 2017
- Posts
- 3,629
- Reaction score
- 4,455
- Ram Year
- 2016
- Engine
- 5.7
It gets tougher to both try to troubleshoot over a computer and in person if there isn't anything as far as codes.
It could be as simple as a bad coil (those do fail) or a bad coil wire/cap/rotor.
It could be as hard as a PCM (fairly rare to go bad), shorted sensor, broken wire, bad ground.
There are 3 wires on most of the sensors, a critical ground wire (I think black/w blue tracer), a 5 V feed wire, and the return wire to the PCM.
How good are you at troubleshooting and finding wiring diagrams?
You could try disconnecting the coil and seeing if there is any voltage between the 2 wires when you crank it (trying to start it and the motor turns over).
