I've been having this issue for about a month now. I'll be driving along at a cruising speed and the truck will shut off occasionally once it's up to temperature. Sometimes the stall will only last for 5 - 10 seconds and other times it won't start until it completely cools down.
I've had the following replaced .. spark plugs, spark plug wires, distributor cap, rotor button, camshaft position sensor or whatever that little round part is called that's under the distributor cap and the battery. The alternator is fine. It was checked at the time the battery was purchased.
Any other ideas? This is getting really frustrating. Thank you!!!
