2001 1500 Noise in Steering
Mutt
Hell Town, Va
I have a noise in my steering. It feels/sounds like it is in the column & it only happens when I'm on a gravel road. The tie rods are tight and there is no wear on the tires. Everything drives & feels great when I'm on hard surface roads.
Is this a known problem? I remember having to replace the lower shaft (between the column & the box) to cure an issue on my old 91 150.
JamOnIt
Check the spring for wear. Where the steering comes thru the fire wall or check your steering gear box
Steve Holtz
