2001 Dodge Ram 3500 Cummins DTC Codes
oldcman
San Marcos ca
2001 Dodge Ram 3500 DWD 4x4 Auto Trans
5.9 cummins
Hello fellows I need Help
My 2001 Dodge Ram 3500 Cummins DWD 4x4 Auto Trans Has DTC Codes P1693 ( 2 Key test) 950, 999 on Dash check and scan tool
Have Check Eng , ABS ,Airbag Indicators On, Have No Speedometer, No AC , No Blower , No power Windows
Factory EVII Security not arming fast blink on valet button
Have Delay on starting have to hold key then engine starts , runs ok except trans shifting funny and unlocking
Other forum s indicated Loss of Main Buss done so I pulled all connector checks bulkhead mains etc
Have No 12V at fuse block for blower nor windows
I have cleared codes with Scan tool , Hard reset by removing batteries )off for hours no help
This issue happen a few month ago and cleared it self after Hard reset by removing batteries
Any help would be most appreciated
Oldcman
O
oldcman
San Marcos ca
5.9 cummins
Update Re checked with scan tool one stored code P0500 Vehicle Speed Sensor
Still have 950, 999 on Dash check
Still had No 12V (1.9v ?) at fuse 2 for Blower relay
Jumped 12V to Fuse 2 blower came on ,all Check Eng , ABS ,Airbag Indicators cleared widows work
All normal ? Did not drive to check speedo This PDC section also powers ABS & windows see schematic
Checking PDC for bad connections or Ignition Switch
Any suggestions would be appreciated Brighton was a big help calling attention to PDC
Thanks oldcman
O
oldcman
San Marcos ca
5.9 cummins
Update
Installed new MOPAR ignition Switch today , Started great , all 900 Codes cleared, Check Eng , ABS ,Airbag Indicators cleared
AC , windows Ok now, speedometer Ok 12V returned to Buss on Fuses 2,3 ,7 10 and CB in the PD on Left side of Dash
Attached wiring diagram but my not have uploaded
Will update my vehicle details as soon as I can navigate this site better
Thanks Hope all stays well
OLDCMAN
Gr8bawana
6.7 CTD
Glad to hear you're making progress. :cheers:
O
oldcman
San Marcos ca
5.9 cummins
Thanks keeping my fingers crossed all’s well so far
Reticle918
