2004 1500 5.7l recurring problem, low idle misfires, no MF under load.
Bills86e
tampa bay
5.7L Hemi Longbed
rpm at idle goes 200. MPG OH counter 7.8 MPG. I had had similar problem so replaced engine. Now have 16k and still cannot figure same code p0300 misfire cylinder 7.
New injectors, spark resister plugs, wires, & coils. All sensors new, checked all last week. last week, & new oil/filter. Pulled driver side valve cover and all in spec.
Can PCM be culprit?
jws123
nj
Did you check compression on all cylinders? Its almost never a PCM issue also did you check for vacuum leaks?
B
Bills86e
tampa bay
5.7L Hemi Longbed
soon as the rain stops. Going to throw another CPS, gets here Friday. How do I check intake manifold? While running I did spray (lightly) but no change in engine rpm.
B
Bills86e
tampa bay
5.7L Hemi Longbed
OK, I have the fix, I,ll explain. The new CPS resulted in No Change. P0300 is the result of mil light. Low oil pressure makes hemi tick more prominent.
Since the rpm is controlled by the PCM, it is BAD, and I have ordered a Plug & Play PCM from FlagshipOne $228 shipped.
When RPM goes low, there is no way to get it back to 750 RPM.
When the 5.7l goes lower than 650, oil pressures are low to almost non-existant, ticking begins.
This should also return my MPG to normal. I,ll report back.
Queation: Are 4wd shocks compatable with R2wd trucks?
B
Bills86e
tampa bay
5.7L Hemi Longbed
Will not idle 750, at 200, lifters clattering, op goes to zero oil pressure.
good compression, new HV melling op, freshed oil & filter, air filter, new pcm,
new exhaust manifolds & cats pipes, new battery, throttle body, op sensor,
coils, injectors. This is whacking my brain, I need advice.
Ken226
Washington State
Have you checked the cam/lifters/valve springs.
For us 4th Gen guys, the p03xx cylinder misfire codes usually result in a cam swap or valve spring replacement. Especially on engines that have spent a lot of time idling.
It may not be a cam/valve spring issue at all, but since your scratching your head and out of ideas, it's something else you can check.
I think there was just a thread about this a few days ago in the 4th Gen forum. Similar code, broken valve spring.
B
Bills86e
tampa bay
5.7L Hemi Longbed
After removing the oil pressure switch, discovered oil inside the connector, indicating the switch was blown threw and pressure escaping.
problem solved! Bought a new switch, a TEE with extra port, and a manual gauge to mount on passenger side railing. 65lbs now. Replaced the EGR & PCV,
engine now running smoothly, re-learning the throttle idle now.
B
Bills86e
tampa bay
5.7L Hemi Longbed
PLEASE READ: https://charm.li/Dodge or Ram Truck...g System/Alternator/Diagrams/Connector Views/
I am Upgradeing all the goodies, touch screen, oil filtration, lighting, exhausts, to 300 amp Alternator & grounds. My new Alt plug harness needed new orientation.
If you buy a bigger Alternator make sure the field wires are correct, or you will short out the PCM. Got my help from charm.li then click enter.
Yours Truly, Bills86e
B
Bills86e
tampa bay
5.7L Hemi Longbed
Dying idle back. WTF. What is going on here? What can be cause of no rpm?
Zoe Saldana
california
6.4l
Can PCM be culprit?
check fuel pump psi
B
Bills86e
tampa bay
5.7L Hemi Longbed
All this is very mystifying. Under the battery box is the accelerator pedal positioning sensor. From what I have read helps control idle.
ZOE, you said you replaced ALL Sensors, Does this mean the TPPS under battery box?
Zoe Saldana
california
6.4l
I didn't say that.
B
Bills86e
tampa bay
5.7L Hemi Longbed
On May 10 you stated your 8 year old truck has : all new: sensors.
Today, I am replacing my throttle body & a do re-learn. Tes, sensors have to be PCM relearned.
B
Bills86e
tampa bay
5.7L Hemi Longbed
The NEW TB was wasted money. No change. Now I replaced Everything except: 2003-2004 ram 1500 accelerator pedal position sensor. Pt # 53032456AE.
I tried new everything. Searching now, Anyone have one? Deal tells me discontinued mfg in 2020.
jws123
nj
did you do a idle relarn when you installed the TB requires scantool
B
Bills86e
tampa bay
5.7L Hemi Longbed
Yes, that was a simple turn key to on, wait 5 seconds, slowly push pedal all way down, release, key off, start.
I looked at 14 trucks, but they were all picked of the APP sensors.
I am going to my other pick n pay yard. 03 & 04 with 5.7l hemi's. they have 11 of them.
i
B
Bills86e
tampa bay
5.7L Hemi Longbed
No DTC codes. Did a Smoke test and found the new EGR valve is fauty and smoking. 3 mo warranty just ran out. Will get another. Dormans are junk.
