2006-2008 front strut fox coilover
inktoxicated
nj
so with my lift kit i want to replace front struts as well. no scense in keeping the stock struts in there at 65k. im thinking it may just be easier to get the monroe quick struts. that way i can just bolt them right in without any fuss.. are monroes good? whats up with this fox coilover?? i dont understand how it can work with the bottom not being a fork? ideally thise would look great to match the rear fox
Dodge Ram Shock - 2.0 Performance Series Coil-over IFP Coil-over Shock | FOX 1500 - Not Megacab&year=2008-2006&position=Front&ref=filter
redram2007
Colorado Springs (Ft Carson)
If you notice at the bottom of the pic it says... Image may not be application specific so more than likely if they offer it for our trucks it will be the same as OEM. Just better quality. I honestly haven't heard much about them but the high price on them should mean good quality.
redram2007
I would recommend calling a dealer that sales them and ask more questions bc even after searching the part# i couldnt find an actual picture that is compatible but if they say its for the 06-08 then it has to mount correctly.
inktoxicated
inktoxicated
nj
tru. its a nice lookn unit. i was going to replace my struts with just oe qaulity, was going to do quick struts so i can just unbolt the whole spring/strut together. would n pretty sweet dropping the foxs' in there to match the rear shocks
redram2007
I just ordered my bilstein 5100s from aoutanything for 169 for 2 with a discount code and free shipping. And you can adjust those from 0"-2" for a level or just oem ride height. I have pulled the strut assembly off before to add the leveling spacers and it was pretty easy so if you buy or rent the spring compressors it should only take an extra hour or two of time to just replace the struts. Im gonna tackle that this weekend weather permitting.
inktoxicated
inktoxicated
nj
169 for both is a good deal. imma jump on those
redram2007
Yes it is i just got mine yesterday and im going to install those change my crank seal and change the oil tom should be a long fun day of wrench turning.
Robstar
Those things are bad ass! I wonder what the MSRP is? I found the matching rears on Ebay yesterday for $225 for the pair.
Edit: I found them on PolyPerformance.com for $400 a piece or Eshocks.com for $360 a piece. Not a bad price for a full replacement adjustable coilover!
inktoxicated
inktoxicated
nj
no its not to bad at all for coilovers.. i decided to just go the bilstein 5100 strut with stock spring setup. truck goes in january 25th for the lift. I went with bilstein 5100 all around and the zone 6' kit. bds stabalizers and traction bars. should be done monday if i can come up with the money to pay for it :):Grenade:
