AlexT
Hello, I've got a 2009 5.7L with 173k miles on that has been having issues with a shaky idle and occasionally a P0306 code that I've been chasing for a while and am not sure where to go next.
Symptoms: Misfire at idle that goes away under load or above ~1k RPM, it is definitely a lot worse on a cold start and seems to improve once it warms up but never completely goes away. I can still rev out the engine smoothly and haven't noticed any decrease in MPGs. I've found if I let it idle too long, it will throw up the P0306(cyl 6 misfire) code but it doesn't count any misfires at cruising rpms. Occasionally it will misfire as I slow down for a turn. It has never stalled on me. I can also hear an intermittent ticking coming from the passenger side, I think it has been there a while but I always assumed it was an exhaust leak tick because I have a few broken exhaust manifold bolts on the pass side. Now I'm not so sure.. In the video you can clearly hear the intermittent ticking at about the 14s mark. Usually its more apparent when the engine is cold started and gets a little better once warm.
https://youtu.be/Yroy4vEEyvA
Diagnosis attempts: I started by checking out the spark plugs (looked good, only 25k miles on them) and coils, and also swapped them between cylinders but the misfire did not follow. I replaced the injector on that cylinder with a new mopar one and saw no change. I thought maybe it was a vacuum leak so I replaced the intake manifold gaskets, cleaned up the intake/TB, and still saw no change. I checked compression between cylinder 6 and 4 and they were similar and seemed to be in a good range. I changed the oil with penzoil platinum 5w20 since it was due already and it may have helped some but it is still present. I took an oil sample and sent it off for testing in the process but it will be a few weeks before I get the results. Lastly, I popped off the passenger valve cover to check for the dreaded lifter/cam failure issue I've been reading a lot about and it was inconclusive, at least to my eye. My neighbor is a mechanic and I had him come over and take a look with the valve cover off, he checked tension on the rocker arms/springs and watched it turn over and didn't notice anything abnormal either. Here's the video I took:
So that's where I'm at and I'm kind of lost as to where to look next. It drives around just fine but misses at idle. Has anyone dealt with this before or have any ideas of what to check next? At this point I'm thinking it could be a sensor or something PCM related? Part of me thinks it could be a lifter, but I'm not sure why it would miss at idle and not at high RPM. Any help is appreciated, thanks.
